Is there a thread for servicing the 3.0 TPS? #766624 11/20/06 11:29 PM
dogtoy Offline OP
I thought that I read once someone talking about servicing there TPS on a 3vze. I noticed that my timing did not change when jumped, so am pretty sure that it's not working properly. Although my truck truck runs well, maybe I can make it run even better. Anyways, take it off, clean it up, adjust and that should be it right? Anything I need to watch out for? Thx guys.
2014 FJ
Re: Is there a thread for servicing the 3.0 TPS? [Re: dogtoy] #766625 11/20/06 11:42 PM
4Crawler Offline
Re: Is there a thread for servicing the 3.0 TPS? [Re: 4Crawler] #766626 11/21/06 08:54 AM
dogtoy Offline OP
Thank you.
2014 FJ
Re: Is there a thread for servicing the 3.0 TPS? [Re: dogtoy] #766627 11/21/06 09:25 AM
kewlynx Offline
Also, that '93 FSM sticky'd at the top in this section will get you in the ball park for your '91 for other stuff. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: Is there a thread for servicing the 3.0 TPS? [Re: kewlynx] #766628 11/21/06 03:03 PM
I'm starting to think my TPS may be suspect and causing the pinging that I get. I don't notice the timing change when I jumper the test connector either.
Re: Is there a thread for servicing the 3.0 TPS? #766629 11/21/06 07:41 PM
dogtoy Offline OP
I'll play w/ it today Jeff and let you know what happens.
2014 FJ
PHP: 7.4.33 Page Time: 3.029s Queries: 15 (0.004s) Memory: 0.6085 MB (Peak: 0.6777 MB) Data Comp: Off Server Time: 2026-06-17 14:55:24 UTC
