first gear trouble
#766633
11/20/06 11:50 PM
all the other gears work fine, but first, i ws told not to be hard on the shifter because i will riune the nylon bushings in between the gears. so if i back up and need to start off i try and go to first gear and it just won't go in. so i go back to reverse and try agen but still won't work. then i go through all the gears and sometimes it will work. what it rong with it?? and how do i fix it??
Re: first gear trouble
#766634
11/21/06 10:51 PM
The first gear synchro is probably bad but you won't know a thing until you pull the transmission and inspect it.
John Smith 79 FJ40 87 StdCab w/22R TLCA# 9074
[Re: John Smith]
#766635
11/21/06 11:00 PM
Could be a worn pilot or throw out bearing also. Once it's in gear with the clutch on the floor, does it tend to creep forward at all?
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#766636
11/22/06 10:48 PM
nope, when i puts the cluch in she don't move. if i have the cluch in and put it in gear it still don't idle down or nuthing. so i really don't no what it is but i no it isent my thro out bearing. because it was fine when i put the new motor in.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5921 MB (Peak: 0.6511 MB) Data Comp: Off Server Time: 2026-10-24 17:28:18 UTCValid HTML 5 and Valid CSS
