blower relay location #766637 11/21/06 02:21 AM
Hey there, I'm new, I have a 96 trooper and I have a strange problem... I had my alt. changed, and apparently my relay which turns on the batt and brake indicator lams when the alt. is going bad has gone out. Problem is that I don't have a relay box diagram... it's not on the cover anymore, this relay also controls my heater blower / a/c, but I don't know what relay it is <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: blower relay location #766638 11/21/06 03:06 AM
bump... if anyone could just look under their hood at the diagram, I think it'll be called charge/ charging or heater/ blower fan relay... driving in a cold truck is gettin old <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: blower relay location #766639 11/21/06 05:45 AM
Re: blower relay location #766640 11/21/06 06:01 AM
thanks man, tis now midnight here, and I tried all the ones that could be related and nothing... has this ever happened to anyone else? 4x4 light, Batt light, and brake indicator light is on, and I have no heater blower / A/C... <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: blower relay location #766641 11/21/06 07:06 AM
I was doing some research, and it seems like the trooper uses a 75 amp unit... I am pretty sure they gave me a 60 amp... could this be the issue problem???
Re: blower relay location #766642 11/21/06 08:10 AM
trooperbc Offline
....has this ever happened to anyone else? 4x4 light, Batt light, and brake indicator light is on, and I have no heater blower / A/C... <img src="/forums/images/graemlins/frown.gif" alt="" />
this is a classic symptom of a failing alternator on the isuzu. (or a big box cheap 'rebuild' unit even if 'new').
you probably would have gotten more replies about this except your initial post got us sidetracked to relay info. all sorts of weird dash light happenings occur when the alternator starts going bad (even trans problems will surface because of defective alternator).
generally, most will tell you to stick to quality alternator alternatives...in descending order of $, but all should be good
*dealer new
*dealer remanufactured
*remanufactured by bosch (my personal favorite from experience)
avoid:avoid:avoid::cheapo rebuilds from bigbox parts stores. if they say "lifetime warranty" be afraid, be very afraid. it means a lifetime of replacing them.
hth
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: blower relay location [Re: trooperbc] #766643 11/21/06 08:19 AM
so did the shop give me the wrong alt.??? they put in a 60amp
Re: blower relay location #766644 11/21/06 11:22 PM
looks like 60amp=without a/c
and 75amp= with a/c
they both look the same
Re: blower relay location #766645 11/22/06 06:56 AM
and 75amp= with a/c
yep they gave me the 60 amp... I even asked them if they were sure... gotta go tomorrow and make a stink
Re: blower relay location #766646 11/22/06 03:09 PM
A
atfdmike Offline
Hi, I have a 94 Trooper, and when my orig alt. went bad when I went to parts store I have been given the right alternator (rebuilt) and had it be bad right after installation. The symptoms are exactly the same as you describe. I could not believe I had to change it out again. I spent a little more and got a better alternator and, knock on wood, over a year now and no problems.
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.009s) Memory: 0.6195 MB (Peak: 0.7236 MB) Data Comp: Off Server Time: 2026-11-02 11:41:07 UTC
