Re: Intercooler on C223T [Re: Viking_t] #767180 12/26/06 05:36 AM
V
Viking_t Offline OP
Finally I got the intercooler in place.
Here is the link for more Pics of the intercooler.
Re: Intercooler on C223T [Re: Viking_t] #767181 12/31/06 01:26 AM
OutfitBoss Offline
Very clean looking work.
Brian
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: Intercooler on C223T [Re: OutfitBoss] #767182 12/31/06 01:30 AM
A
acy76 Offline
Installation looks nice. Have you noticed any change in performance since the addition of the intercooler? Any modifications to fueling etc.?
1988 Isuzu Trooper LS
2.8l Isuzu 4JB1-TC intercooled turbo diesel
www.dieseltrooper.blogspot.com
Re: Intercooler on C223T [Re: acy76] #767183 12/31/06 12:18 PM
V
Viking_t Offline OP
I have not done anything to the fuel adjustment yet. I have shorten the wastegate rod to increase boost. Perfommance is excelent I can go up hill in 4th gear without any prob. It seems like more power at about 2800rpm, I can go from 100km/h to 120km/h easily. There is plenty of power left, I hardly need to put the foot on the floor now. Worth of 5 hours work, very happy.
Re: Intercooler on C223T [Re: Viking_t] #767184 01/01/07 01:29 AM
OutfitBoss Offline
Yeah man that's sweet.
I have to ask the stupid question right away to show my ignorance. Did you pull the factory turbo and add the intercooled turbo? Your work is so clean I can't tell but it looks like you added the thing-a-ma-jig on the top and away you went. Where did you go to find out how to do this mod? Or, did I miss the whole thread and my bad?
Brian <img src="/forums/images/graemlins/baby.gif" alt="" />
Brian Rodgers
www.outfitnm.com
Re: Intercooler on C223T [Re: OutfitBoss] #767185 01/01/07 02:09 PM
V
Viking_t Offline OP
That turbo comes with the engine, I only needed to modify the inlet fitting by 90 degree (it used to point backward to the firewall for the turbo fitting and now I have it pointing toward the intercooler).
The process quite straight forward:
1) Measure the inner section of the intercooler (only the core area)
2) Cut the hole on the bonnet with the area above ( find the right place in engine bay first to see if anything will be on the way first of course -:)
3) Close the bonnet then get the string to mark left+right cuts then front+back cuts so you have 2 marks on the guards and so on...
4) Open the bonnet use masking tape to join the marks and the small area enclosed by 4 lines in the middle is the bonnet scoop hole.
5) I used temporatory brackets to hold the intercooler up then adjusted the gap b/w the bonnet and the intercooler, I then left those brackets in place and made the perm ones to secure the intercooler in place.
6) Finally the pipes.
The whole thing took about 5 hrs for me (excluding 2 hours to weld the aluminium inlet then file it down)
By the way, I just got back from a long trip today. Fuel consumption seems to be better as well, I got 620km from ~52L of diesel, mainly on hwy at 100km/h
Re: Intercooler on C223T [Re: Viking_t] #767186 01/01/07 11:55 PM
OutfitBoss Offline
So the main purpose of the intercooler is to cool the air after the turbo and before the intake mainfold?
Brian
Brian Rodgers
www.outfitnm.com
Re: Intercooler on C223T [Re: OutfitBoss] #767187 01/02/07 02:00 AM
V
Viking_t Offline OP
Yeah that is right, cooler air has more density. The air passes though the turbo is being heated up so it needs to be cooled down again. You probably don't need one at your place as its cold all year around javascript:void(0)
Re: Intercooler on C223T [Re: Viking_t] #767188 01/02/07 04:38 AM
OutfitBoss Offline
All right, thanks for the clarification
Brian Rodgers
www.outfitnm.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6367 MB (Peak: 0.7418 MB) Data Comp: Off Server Time: 2026-06-17 03:22:35 UTC
