Page 3 of 4 1 2 3 4
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767431 11/29/06 12:04 AM
Rauch_Off_Road Offline OP
Where is a good place to get a highpinion front carrier w/locker? I would imagine the dealer would want my first born.
(aka suprathepeg, aka Sean)
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767432 11/29/06 06:28 PM
Staceman Offline
Carrier
Toyota Land Cruiser 4X4 11572 $400 Suwannee Auto Salvage USA-FL(Live-Oak) E-mail 1-800-533-5458
This junkyard claims it's an E-Locker (Front Axle).
4.10 ratio for that year. Next cheapest one is $700.
It can be re-geared though.
Re: gear ratios in taco elocker diffs? [Re: Staceman] #767433 11/29/06 06:41 PM
Hmm that looks good. Did you get that from car-part? I couldn't find any there when I looked. Anyone know if the front LC elockers came with 4.56 gearing?
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767434 11/29/06 06:47 PM
DirtyHarry Offline
Toyota Moderator
4.10 was the only ratio available in the North American FZJ80.
Re: gear ratios in taco elocker diffs? [Re: DirtyHarry] #767435 11/29/06 08:53 PM
dcg9381 Offline
Is that the high pinion version?
22REturbo.net
1988 4Runner
Re: gear ratios in taco elocker diffs? [Re: dcg9381] #767436 11/29/06 09:19 PM
Yea
Re: gear ratios in taco elocker diffs? [Re: dcg9381] #767437 11/29/06 09:25 PM
Staceman Offline
Yes, info from Car-Part.com
Yes, most definitely high pinion.
Re: gear ratios in taco elocker diffs? [Re: Staceman] #767438 12/02/06 06:49 PM
So I've been reading up on the e-locker installation HERE and have a question.
The article says the Tacoma one won't fit into a standard 8" case. Is that confirmed?
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767439 12/02/06 06:55 PM
4Crawler Offline
As it says:
Tacoma TRD electric locker also uses an 8.0" ring gear and what appears to be the same electric locker as Toyota used in the 4Runner. It doesn't look like this electric locker will retrofit it into the 8.4" non-TRD Tacoma axle with an open differential unless you obtain the entire TRD axle along with the locker.
The e-locker (8") won't swap into a 8.4" Tacoma rear axle (non-TRD) or carrier. I think all the e-lockers will fit into any of the 8" axles (front or rear) with the proper mods.
Re: gear ratios in taco elocker diffs? [Re: Rauch_Off_Road] #767440 12/02/06 06:57 PM
ErikB Offline
Toyota Moderator
Is this what you are referring to?
The locker I bought was meant for an 8.0" Toyota axle. Erik Bibelheimer recently posted in the 4x4wire BBS that the Tacoma TRD electric locker also uses an 8.0" ring gear and what appears to be the same electric locker as Toyota used in the 4Runner. It doesn't look like this electric locker will retrofit it into the 8.4" non-TRD Tacoma axle with an open differential unless you obtain the entire TRD axle along with the locker.
If so, basically all that its saying is the 4runner and Tacoma e-lockers are the same. They are 8" lockers and they fit in 8" housings.
The e-lockers (or any standard 8" diffs) will NOT fit into housings that use the T100/Tundra/Tacoma (aka, 8.4") type diff.
This may also help: http://home.4x4wire.com/erik/diffs#rear
*Note- the so-called 8.4" does not really measure 8.4", but thats another story!
[Edit- Roger just barely beat me to it! <img src="/forums/images/graemlins/nana.gif" alt="" /> Great minds think alike! <img src="/forums/images/graemlins/smile.gif" alt="" /> ]
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6459 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-06-06 20:25:40 UTC
