Online manual for 84 Toyota Xtra cab #767454 11/25/06 06:05 AM
Anybody know of a online pdf manual for an 84 hilux?
Re: Online manual for 84 Toyota Xtra cab #767455 11/25/06 06:27 AM
i use this http://www.autozone.com/servlet/UiB...tion=processModel&Parameters=013 and the haynes manual
if you need something i can scan it and forward it or someone here will have the info needed
nice to see another canadian
use to live in ottawa now i'm up in north bay
Re: Online manual for 84 Toyota Xtra cab #767456 11/25/06 10:18 AM
larsdennert Offline
How about this? http://67.122.16.97/danny/misc/1985FSM.pdf '84 and '85 are virtually identical as are trucks and 4Runners.
Re: Online manual for 84 Toyota Xtra cab [Re: larsdennert] #767457 11/25/06 05:00 PM
Thanks for the reply guys
Maybe make this thread sticky?
Re: Online manual for 84 Toyota Xtra cab #767458 11/27/06 02:22 AM
kewlynx Offline
We've already got a sticky here for FSM's. You can toggle this thread at the bottom and put the other links offered to you in your faves.
Only problem you *might* run into with using the 85 FSM for an 84 is that the ignition system might be the early configuration (external voltage regulator). Just so you are aware.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5957 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-05-28 00:55:04 UTC
