Re: Glow Plugs 101
[Re: Brewmaster]
#767622
12/05/06 07:14 PM
I agree on the seperate glow plug thread ...
Simple for the heat part P=ExI (Power = Volts times Current)
So in theory a 12V is "more gentle" on the system WRT current draw to get the same effect (power)...
It may be of benifit to retrofit to 12V for our winters ??
97 Prado (LC 90 series) JDM import 2020 --- 2000 Galloper II SWB under offer from Korea 88 Mits Pajero LWB 185000Km 2.5TD JDM import (SOLD)
Re: Glow Plugs 101
[Re: bill_bly_ca]
#767623
12/05/06 11:51 PM
It may be of benifit to retrofit to 12V for our winters ?? Not sure I follow. What do you mean by "retrofit?". The system currently (pun intended) dumps a full 12v to the plugs for the initial glow, then drops down to 6v for the "afterglow" while the truck is running. And therin lies my conundrum. What's the diff having 6v plugs vs 12v plugs in the system? The plugs really don't care how much voltage they get. They just turn whatever they have into heat. I'm sure there is a reason and I'd like to know what it is.
Kelvin 91 Pajero Exceed - Controls mounted curb-side for convenience 82 Mercedes 300SD
Re: Glow Plugs 101
[Re: Brewmaster]
#767624
12/06/06 12:21 AM
It may be of benifit to retrofit to 12V for our winters ?? Not sure I follow. What do you mean by "retrofit?". The system currently (pun intended) dumps a full 12v to the plugs for the initial glow, then drops down to 6v for the "afterglow" while the truck is running. And therin lies my conundrum. What's the diff having 6v plugs vs 12v plugs in the system? The plugs really don't care how much voltage they get. They just turn whatever they have into heat. I'm sure there is a reason and I'd like to know what it is. On mine I have 6.5V all of the time.. I never have never seen 12V on my plugs.. From Off to on there is about 7 seconds of 6.5 V and then there is 4 or 5 cycles of the 6.5 V once the motor is going... Hummm
Re: Glow Plugs 101
[Re: bill_bly_ca]
#767625
12/06/06 05:37 AM
Hummm
My apologies. I have just assumed from what I read that it was 12 and then 6. I will have to take a meter out this weekend and check.
Re: winter
[Re: Brewmaster]
#767626
12/09/06 08:01 PM
I ended up buying some NGK plugs that work but are 11v not 6.2v.
Did you bypass the ballast resistor then to get the full 11V to the new plugs? Nope. I just took out the greentops and put in the NGK's. I thought about doing that but I didn't feel too comfortable doubling the voltage to the plugs for an extended period. In theory it should be fine but.... Anyway, I'm still hunting for the Greentops. The NGK plugs were $7.00 each plus $10.00 shipping from the states. So for less than the price of one Greentop from Mits I have 4 NGK's that work. Albeit not stellar, but functional. Okay - so what was the part number on the NGK? I like the idea of locally sourced parts. Are they working well? Where did you get them for $7 each?
1991 JDM SWB Pajero TD - Sold.... 1997 Dodge Ram 2500 Cummins 4x4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6160 MB (Peak: 0.6821 MB) Data Comp: Off Server Time: 2026-06-17 13:43:16 UTCValid HTML 5 and Valid CSS
