Where to mount a temp sensor or 3VZE 3.0 V6? #767646 11/26/06 08:23 AM
ScaldedDog Offline OP
Does anyone (Rauch?) know where to mount an aftermarket temp sensor on a 3.0 V6? I'd like to mount it just before the thermostat, but I'm not sure the thermostat housing is thick enough to tap effectively. I searched and found a reference to an in line mount from Custom Aluminum Radiator. Since I don't yet know if that'll work, I'm looking for other options. Anyone have any ideas/
Thanks,
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: Where to mount a temp sensor or 3VZE 3.0 V6? [Re: ScaldedDog] #767647 11/26/06 10:00 AM
Rauch_Off_Road Offline
(aka suprathepeg, aka Sean)
Re: Where to mount a temp sensor or 3VZE 3.0 V6? [Re: Rauch_Off_Road] #767648 11/26/06 06:53 PM
Good idea! So drilling and tapping the JBWeld worked fine?
Mark
Re: Where to mount a temp sensor or 3VZE 3.0 V6? [Re: ScaldedDog] #767649 11/26/06 07:51 PM
Mark
Yep. I also used teflon tape to ensure a seal. You could add the JB weld after you have the probe installed, like OOPS did. This is the hottest point for the coolant so you get some interesting readings, hehe. I got the idea from OOPS, Shout out to OOPS for the idea.
Be sure to let the JB weld fully harden before you tap it though.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6011 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-03 12:52:44 UTC
