I only have 4-lo??? #768013 11/28/06 01:31 AM
8
84YOTA Offline OP
my 2wd and 4hi are currently not working at all the shifter shifts through all of them...its not stuck...what are the possiblilities..just bought the truck for cheap and have an extra top shift t-case lying around but would still like to know what the culprit might be for the forward shift that doesnt have 4 hi or 2wd...but the shifter is not stuck...right now it drives in 4 low with the rear driveline removed
84 toyota std cab with stuff on it
Re: I only have 4-lo??? [Re: 84YOTA] #768014 11/28/06 03:45 AM
rednekbean Offline
the only thing i can really think of would be that the shift lever is not in the possition it is suppose to be in on the shift levers so it is simply not moving the shift levers. i would think that you would not be able to feel the lever "click" in to the different gear selects. that would be just take the top plate off and check were the shift lever is.
nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: I only have 4-lo??? [Re: 84YOTA] #768015 11/28/06 06:29 AM
Yea fix it so i can have it for my truck...
PHP: 7.4.33 Page Time: 2.018s Queries: 15 (0.004s) Memory: 0.5898 MB (Peak: 0.6448 MB) Data Comp: Off Server Time: 2026-06-07 19:12:09 UTC
