trooper stalls
#768126
11/28/06 03:04 PM
hey everyone. my 89 2.6 isuzu trooper is having a little trouble. it starts up just fine runs and idles just fine. but after Ive been driving for about 30 minutes it starts to get really sluggish and if I press the accelerator I have no power at all and then it will just end up dying. once it dies I can start it right back up with no problems and it runs fine again for another 15-20 minutes before I have the same problem. its not overheating when it does this and I have plenty of gas. any thoughts?
Thanks Chris
Re: trooper stalls
[Re: dozier13]
#768127
11/28/06 06:34 PM
MAF sensor maybe. Crappy vacuum line somewhere, how about the coil? Mine used to stall after 20 min of driving as a result of the coil, it also got sluggish to. Just throwing some ideas out there to get you started somewhere. Start Simple to narrow it down.
89'Isuzu Trooper LS 5 spd 2.6L 31" Big O X/T's 15x8 Eagle 058's K&N Filter w/ Air Box Mod 2.25" DynoMax SuperTurbo PolyUrathane/Indy4X Bushings Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: trooper stalls
[Re: dozier13]
#768128
11/28/06 10:14 PM
Plugged up EGR system can bog engine mightily. If you haven't cleaned it in some time it probably needs it. Include the passage behind the throttle body that's cast into the throttle chamber. You'll need to pull that big cap at the firewall end of the casting to let whatever you blow out/drain out. While you're at it you might want to give all the vacuum line fittings that sprout from the throttle chamber a squirt of carb cleaner. On some of mine the insides of the vacuum lines were filled with a tarry goo that filled the ports (good time to change out the vac lines if they are filled with goo). Check the back pressure transducer too (brow top shaped thingy). It supposed to let vacuum pull open the EGR valve when the back pressure from the exhaust system pushes an internal membrane which opens the vacuum passage. If that membrane ruptures it lets hot exhaust gas into the transducer and that's the end of that device. Bubbly looking top is a good indicator it's cooked. Isuzu has to match the numbers to replace it so bring it with you when you go to the counter.
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5908 MB (Peak: 0.6442 MB) Data Comp: Off Server Time: 2026-06-10 02:24:01 UTCValid HTML 5 and Valid CSS
