New member to the forum
#768280
11/28/06 11:05 PM
Hello guys, this site is awesome. I never knew that Montero was capable of such off roading. I recently purchased Kumho Venture HT 31x10.5R15 for 1991 Montero, and it has a OEM rims. But when I took it to a shop, they wont put the tire on because they'll rub. My question is, what kind of adjustments do I need to make to fit these on there. I look ed that the diagram from the FAQ, but can't really figure out where to make the cuts. If anyone has a picture of the cuts that they made. I would really appreciated.
thanks for all your help. There might be another post that's similar to this one. i could find the first one i posted.
Re: New member to the forum
#768281
11/28/06 11:22 PM
I don't agree with them rubbing.. worse case you might have to crank your torsion bars a little to bring the front level with the rear.
Welcome to the forum!!
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
#768282
11/28/06 11:43 PM
Find another tire shop where someone has a brain.
Frank
#768283
11/29/06 12:30 AM
They wont rub. It's just a lie they tell. There insurance will not allow them to sell tires that are not OEM size. Find another shop.
Welcome to the wire <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: LRJ4x4]
#768284
11/29/06 12:52 AM
That is BS, go to a different shop they are stupid. But, according to the chart in 4Wheeler, you will need a 3in body lift to fit 31s.
#768285
11/29/06 01:21 AM
Thanks for all your input, I was looking at the diagram. It seems like it might rub little bit on the inside, but "you will need to trim back the front bumper endcaps" where is the front bumper endcaps located? the inside or the outside?. If anything, i'll find out where the tires are rubbing and just cut the piece out.
#768286
11/29/06 02:36 AM
Trimming the bumper endcaps should only apply to running 33's, not 31's. I ran 31x10.5x15 tires on stock rims for a while without any modifications at all and they never rubbed.....ever.
I've been running 33x12.5x15 tires on 15x8 rims for about a year and a half now. My bumpers weren't an issue because I swapped both front and rear bumpers out for a set of don custom bumpers. Granted, I have a 2" body lift, but the word is that even without the lift they shouldn't rub (I did my body lift and tire swap at the same time) except for on the bumper end-caps. The only thing which ever (briefly) rubbed was the splash-shields at the front of the front wheelwells. You can easily bend them a little bit forward with your hand to correct that problem.
But 31's on stock rims rubbing? Nope, they won't.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#768287
11/29/06 02:51 AM
Nothing to add about the Tires/Rims,its all been said.Add your info about your Monty to your signature like most of us have done. It makes it easier for us to know what you have when you have questions.And last but not least Welcome to the Wire <img src="/forums/images/graemlins/kewl.gif" alt="" />
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED Happy trails to you (1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear (2)95 4Runner All Pro Nerf bars BFG 32s ARB bull bar Downey 2" rear coils Downey headers (3) 90 Montero LWB 3.0 auto (4) 98 Kawi GPZ1100
[Re: 4xmonty]
#768288
11/29/06 03:15 AM
On a gen1 with leaf springs in the rear might rub the inner fender/frame on rear when flexed all the way with stock tires. You will not rub with 31s.
[Re: sparkem]
#768289
11/29/06 03:49 AM
I had a bit of inner fender scrubbing on the rear of my 88 with 31x10.50's on stock rims if you get your self a set of after market 15x8 wagon wheels or something you'll be set and when you want to go bigger you won't need to get rims then.
89 2 dr turbo diesel 89/88 "Backwoods sas"
