Starting #768477 11/29/06 08:01 PM
DentedTacoma Offline OP
I just replaced the battery on my truck a couple few weeks ago and it has been doing well. Now suddenly sometimes it just clicks when I try to start and then if I wait a couple minutes after that it starts right up? (Sometimes it works fine though) Whats the deal? Also there are squealing belts on startup if that has anything to do with it. My buddy told me to rev the engine a bit and put it up in rpms after I start it up and then the squealing goes away (which it does). Not sure quite what is going on, any ideas?
98' Toyota Tacoma SR5
Manual Xtra Cab, Slight Lift
Maine Rules!
Re: Starting [Re: DentedTacoma] #768478 11/30/06 01:21 AM
Toy4x Offline
You've got two issues.
The 'click click' is the classic starter contact sympton, common with Toyota / nippon denso starters. The battery replacement is likely merely coincidental, however recheck the connections to make sure they are tight & clean.
See Roger Browns site for complete starter troubleshooting:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
On the belt squeal, typically the belt is slipping until it warms up. Likely one or more are slightly loose, and can also be giving you advance notice that one of the items associated to the belt(s) in question has gained resistance, and may need replacement soon. Tighten one at a time to determine which, and go from there.
Re: Starting [Re: Toy4x] #768479 11/30/06 08:15 PM
Another thing is that I get a really high idle off the bat when started. I know that it idles higher until it is warmed up but I am talking 2000rpms for about 5-10 seconds. It is about 67 degrees out, I don't think that warrants a cold start up. Any ideas on that one?
EDIT: This only happens on occasion. Recently about 1 out of every 5 starts.
Maine Rules!
Re: Starting [Re: DentedTacoma] #768480 11/30/06 08:27 PM
RichinROA Offline
Take yer' foot off the long skinny one when ya start it.
J/K. mine does it too, but seems only in the colder months.
I assume you have an automatic? I've never heard of a manual doing this. Even back in my S10/lazer days, the automatics would sound like they had a flex fan sometimes at startup.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: Starting [Re: RichinROA] #768481 11/30/06 10:52 PM
Well strange thing is that it is a manual. It only revs it up for a bit and then settles back down. Sounded weird but maybe it will be a good Toyota and fix itself.
Maine Rules!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6052 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-05-26 14:11:57 UTC
