Page 2 of 3 1 2 3
Re: opinions...on buyin a used distributor [Re: Staceman] #768771 12/01/06 01:35 AM
I
irish_ROCKS Offline OP
how do u determine straight up???? or is jus eying it close enough??
the guy from rhode island is reealllly nice.........jus missed his ups time tho soo couldnt overnight it
wound up gettin it from cali for 100 including next day
next day usually added 40 -60 bucks
should be in town tomorrow morning thanks for the help man <img src="/forums/images/graemlins/kewl.gif" alt="" />
irish kicks ASS!!!!! ;-p
Re: opinions...on buyin a used distributor [Re: irish_ROCKS] #768772 12/01/06 03:33 PM
Staceman Offline
Eyeballing straight up will get you near where you'll need to be, it will run if off just a few degrees. You'll still have some adjustment for getting it dead on.
Re: opinions...on buyin a used distributor [Re: Staceman] #768773 12/02/06 04:24 AM
dcg9381 Offline
Mark it so you remember...
22REturbo.net
1988 4Runner
Re: opinions...on buyin a used distributor [Re: dcg9381] #768774 12/02/06 05:26 AM
I
the new one looks to be easy as heck to pull the pickup assembly outta...... <img src="/forums/images/graemlins/smile.gif" alt="" />
gotta look at mine in the morning....i might not even need to pull the distributor <img src="/forums/images/graemlins/kewl.gif" alt="" />
tho if you pull it an u put a new one in.......hows markin helpin???0r am i jus tired an not thinkin lol
thanks for all the help guys <img src="/forums/images/graemlins/kewl.gif" alt="" /> ........i'm gettin on it in the morning an HOPEFULLY can swap it in quick an have it alll fixed an ready to roll again
Re: opinions...on buyin a used distributor [Re: irish_ROCKS] #768775 12/08/06 09:13 PM
I
k thanks alot for the help......new distributors in............STILLLLLLL NOOOOO SPARK!!!!! GRRRRRR
Re: opinions...on buyin a used distributor [Re: irish_ROCKS] #768776 12/08/06 09:15 PM
dcg9381 Offline
OK.. that makes no sense, Irish... The ECU is the only thing left.
Have you gone through the FSM diagnostic procedure for troubleshooting spark?
22REturbo.net
1988 4Runner
Re: opinions...on buyin a used distributor [Re: dcg9381] #768777 12/08/06 09:26 PM
I
ummm my post ??? <img src="/forums/images/graemlins/confused.gif" alt="" /> or the problem? lol neither seems to be making any sense today,sorry.
yeah,welll i didnt do the next to last "check IGT signal from ecm" i'm really not sure how,and i dont have the page it refers to
and i didnt check the resistince of the cable between the coil and distributor.........i cant get spark at the coil sooo thats not it ....or am i wrong????
other than that yeah
1 checked wires and fuses.Power to the module and coil.Wiring has no visible cuts,etc that i can see.All fuses look good
2 Redid the two ignition grounds(new bolts,cleaned things up,smeared dielectric grease around).
3 tested the coil...wound up replacing it
4. replaced the module ,couldnt test it and it SEEMED the logical problem......
5.installed junkyard distributor....put on new rotor....
Soo yes sir i have,except for the IGT thingi
Re: opinions...on buyin a used distributor [Re: irish_ROCKS] #768778 12/08/06 09:39 PM
stock87 Offline
What motor, and how did it come to be non-running?
I just went through a no spark problem on a 22RE that turned out to be a badly warped head with no compression. And cylinders full of water. I tried a new coil, ignitor, pickup coil, etc. and when I did the head gasket it fired right up on all the old stuff I thought was bad.
Electrical side isn't always to blame for no spark. Might throw a compression tester on there.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: opinions...on buyin a used distributor [Re: irish_ROCKS] #768779 12/08/06 09:42 PM
dcg9381 Offline
OK.. just confirming that you've walked through the procedure of the FSM - not just stuff that people have recommended.
The FSM that's posted does have those pages.. A few notes:
Info on trouble codes for the V6:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/85diagnosi.pdf
Troublehshooting the IGT is in this section, but it requires the truck to be at idle.. So I really don't see how it's useful..
http://personal.utulsa.edu/~nathan-buchanan/93fsm/engine/86troubles.pdf
Here's how the system works:
http://lakebox.dnsalias.com/photos/1988%204runner/megasquirt/toyotaVAST.jpg
I'd want to know if I get a 5v square wave out the IGT pin (leave the harness connected to the ECU) when cranking. This will most likely show as a 3-4v indication in a voltmeter.. or maybe a swinging indication of voltage on an analog voltmeter like you're using. Test IGT between the pin and ground.
No IGT = No spark.
No IGT could be caused by a bunch of things:
1) Bad pickup on the distributor.
2) Bad Ignitor.
3) Bad wiring between the distributor and the ECM.
You should also check the input on NE at the ECU, again with the ECU plugged into the harness, based on my VAST diagram. It's 12v square wave for the 22RE.. I *think* it's the same for the V6.
22REturbo.net
1988 4Runner
Re: opinions...on buyin a used distributor [Re: stock87] #768780 12/08/06 09:44 PM
I
stock87:
http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
ohhh god now you're scaring me lol
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6442 MB (Peak: 0.7501 MB) Data Comp: Off Server Time: 2026-06-07 03:16:52 UTC
