Re: Loss of power - ECU??? [Re: Ashokan1] #769072 12/04/06 07:42 AM
trythis Offline
The TPS will not affect idle at all, unless it reads that the throttle is not at idle. Mine was telling the ecu that I was at idle at 1/4 throttle, and at full throttle, it must have told the ECu I was at 1/4 throttle. The spring inside the TPS was worn out so when I let off the gas it stuck at what would have been 1/4 throttle, but it was reading idle.
If you sprayed carb or throttle body cleanout on the Throttle body, your TPS is probably taking some damage from the cleaner.
I would at least test the TPS, it is easy to do. You cant even set the timing if it is bad.
Re: Loss of power - ECU??? [Re: Ashokan1] #769073 12/04/06 03:07 PM
fourwd1 Offline
... Truck runs but no power especially on hills.
I'd check the cat conv again, you have the clasic symptoms of a clogged cat.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Loss of power - ECU??? [Re: Ashokan1] #769074 12/05/06 05:29 AM
trythis Offline
Is it a manual or auto? IF its auto, check the linkage under the throttle cable.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5999 MB (Peak: 0.6530 MB) Data Comp: Off Server Time: 2026-06-22 01:05:50 UTC
