Re: EGR valve stuck? [Re: 87Toy4x4] #769087 12/05/06 10:18 AM
VanillaTHUNDA Offline OP
i seriously doubt your egr is clogged if youre getting those symptoms, so i wouldnt worry about cleaning it. i think it has to do w/ your efi system, one of the sensors or something.
True, but why would the engine rev and smooth out when I tap it otherwise? I'd figure the valve itself simply because if the passage is blocked there's no flow regardless, so tapping it wouldn't do a thing. Plus, the valve is brand new. With the exception of two thermo sensors, all the sensors are new and tested/calibrated, most importantly the TPS and O2 sensor. Man, just what I need- ANOTHER mystery problem, lol. <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: EGR valve stuck? [Re: trythis] #769088 12/05/06 10:23 AM
Yeah the tube is cast into the plenum. You can se where the egr pumps into the plenum just behind the intake. My PCV vavle had been clogged for years(?) PO never maintained anything. Egr was toast, tube almost solid, caused my throttle body flap stick.
Wow, I always thought the EGR just recycled into the plenum chamber itself. Given the condition of the inside of the plenum last time I looked at it, I should probably clean the hell out of it, lol. However, if that tube is clogged would tapping on the valve smooth out my idle? Seems that if it was gunked up it wouldn't matter either way since I'd be getting little or no flow. Hmm, regardless I'll remove it and clean the hell out of it but I think I need to go through and test all my emissions components, I wonder if something isn't hooked up right or not working right and holding that valve slightly open...
Re: EGR valve stuck? [Re: VanillaTHUNDA] #769089 12/06/06 06:33 AM
trythis Offline
Interesting problem. I am always trying to make my idle smoother. I wonder if when you tap it the diaphram in it lets some vacuum loose and sends a signal that the car is warmed up, or is running too cool, changing the fuel air mix. MAybe it is affecting the cold start injector, but that is a swing in the dark.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6021 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-06-10 06:17:03 UTC
