crazy headlamps! #769795 12/05/06 08:45 AM
poorboy4x4 Offline OP
Hey, im having a problem with my headlight/ running light system? when i turn my ignition key on, my running lights turn on. When i turn down the dimmer switch the running lights turn off, when i turn on the headlights the all the lights work but the headlights turn on and off all the time(thank goodness for foglights) um, i did replace a relay under the dash coult it be that? or a bad headlamp switch? has anybody experienced this before? any input? thanks! <img src="/forums/images/graemlins/shiner.gif" alt="" />
88 YJ, 4.2L, WEBER 32/36, On 33" Dunlop Mud Terrain, 4.10 ratio, tru-trac locker in dana 35...
Re: crazy headlamps! [Re: poorboy4x4] #769796 12/05/06 03:43 PM
BobRowe Offline
That indeed is a strange one!
But since these problems started right after you changed the relay under the dash, I'd start there. Double check to insure that you installed the relay correctly, and double check to insure tht you used the correct replacement relay. If you are CERTAIN that both are correct, then I would consider the possibility that you disturbed something under the dash when you were under there changing the relay. You may have broken a connection, or shorted a couple of wires there were worn bare, or something of that sort.
Re: crazy headlamps! [Re: BobRowe] #769797 12/06/06 05:53 AM
<img src="/forums/images/graemlins/cyclops.gif" alt="" /> Thanks, ill do that, hell if i did break anything i can at leeast enjoy the cool disco lights my headlights have become! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5924 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-05-30 04:18:20 UTC
