The most miles on sportage
#769882
12/05/06 09:26 PM
Who here has the most mile on their Sportage????? I got 111,0000! (i thought I had more but then i actually checked today). <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: The most miles on sportage
[Re: Hydra747]
#769883
12/05/06 09:36 PM
I have beteen 160 and 180. I'm not sure because I put in 31's and I have more than it says. The obdometer says 160+. Does not burs oil and it's misfiring now because it's been 2 years since my last tune-up. I has been 3 times to Guatemala, Central America from Houston and one of the times it towed a Nissan extra cab pick-up all the way. Also about 20+ times to Mexico.
1985 Toyota 4x4 4Runner. 1989 Suzuki Sidekick 4x4.
[Re: maraguez]
#769884
12/05/06 10:37 PM
98 Sportage
[Re: Hal2000]
#769885
12/06/06 03:42 AM
I've got 83K now but I put 31's on at about 50K so I've got more than that because the odometer is off due to the larger than stock tire size.
[Re: logansportage]
#769886
12/06/06 10:18 AM
I just checked mine 42k. Bought the Sportage used in March 2003 at 8k, body lifted it at 14k, RockSportGear lift installed at 25k and 31's mounted the next day. Pretty much all off road and road-tripping miles. <img src="/forums/images/graemlins/kewl.gif" alt="" />
02 [color:"red"] Sportie [/color] 5sp 4x4 2dr. 1?" Body + 4" Rocksportgear lifts, 31x10.50 Wildcats M/Ts, Manual Hubs, Yakima rack, basket. Redline gear oils http://www.cardomain.com/id/calapooyasMy beater, 03 Land Rover Freelander SE3
[Re: Calappoyas]
#769887
12/06/06 01:36 PM
96.000 miles - 155.000 km <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
[Re: fokion]
#769888
12/06/06 02:01 PM
i have 150,000+ on mine, but it's a lot closer to 200,000 miles actually travelled because i only had the stock tires on for the first 20,000 miles or so. bigger tires make your odometer and speedometer turn slower than the actual amount of miles traveled or your actual speed.
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#769889
12/06/06 04:35 PM
Hey, anyone ever checked the actual speed using 31's. I kind of shecked it with one of those speed things they place on the road during repairs and it clocked me doing 68 while doing 60. Is this pretty much correct or does anyone have a different number? I feel these engine are good for 300,000 miles plus if taken good care of. I have overheated mine a few time, 10 or so times, and it has not given up on me yet. I wish I had the same suspension on my Suzuki that I have on the Kia.
[Re: Cen_Tex_KIA]
#769891
12/06/06 06:28 PM
I know this is a lot if info, but here it is.
Dimensions
Dimension Tire A: 205/75 R 15 (27 x 8.07 x 15) Width 8.07" 205.00mm) Sidewall height 6.05" (153.75mm) Overall height 27.11" (688.50mm) Circumference 85.16" (2162.99mm)
Dimension Tire B: 267/76 R 15 (31 x 10.51 x 15) Width 10.51" (267.00mm) Sidewall height 7.99" (202.92mm) Overall height 30.98" (786.84mm) Circumference 97.32" (2471.93mm)
Difference Width +2.44" (+62.00mm) Sidewall height +1.94" (+49.17mm) Overall height +3.87" (+98.34mm) Circumference +12.16" (+308.94mm)
Speedometer Error
Actual Speed | Indicated Speed with Tire B | Speedometer Error 5 mph (8.04 kph) | 4.38 mph (7.04 kph) | -0.62 mph (-1.01 kph) 10 mph (16.09 kph) | 8.75 mph (14.08 kph) | -1.25 mph (-2.01 kph) 15 mph (24.13 kph) | 13.13 mph (21.12 kph) | -1.87 mph (-3.02 kph) 20 mph (32.18 kph) | 17.50 mph (28.16 kph) | -2.50 mph (-4.02 kph) 25 mph (40.23 kph) | 21.88 mph (35.20 kph) | -3.12 mph (-5.03 kph) 30 mph (48.27 kph) | 26.25 mph (42.24 kph) | -3.75 mph (-6.03 kph) 35 mph (56.31 kph) | 30.63 mph (49.28 kph) | -4.37 mph (-7.04 kph) 40 mph (64.36 kph) | 35.00 mph (56.32 kph) | -5.00 mph (-8.04 kph) 45 mph (72.41 kph) | 39.38 mph (63.36 kph) | -5.62 mph (-9.05 kph) 50 mph (80.45 kph) | 43.75 mph (70.40 kph) | -6.25 mph (-10.05 kph) 55 mph (88.50 kph) | 48.13 mph (77.43 kph) | -6.87 mph (-11.06 kph) 60 mph (96.54 kph) | 52.50 mph (84.47 kph) | -7.50 mph (-12.07 kph) 65 mph (104.58 kph) | 56.88 mph (91.51 kph) | -8.12 mph (-13.07 kph) 70 mph (112.63 kph) | 61.25 mph (98.55 kph) | -8.75 mph (-14.08 kph) 75 mph (120.67 kph) | 65.63 mph (105.59 kph) | -9.37 mph (-15.08 kph) 80 mph (128.72 kph) | 70.00 mph (112.63 kph) | -10.00 mph (-16.09 kph) 85 mph (136.76 kph) | 74.38 mph (119.67 kph) | -10.62 mph (-17.09 kph) 90 mph (144.81 kph) | 78.75 mph (126.71 kph) | -11.25 mph (-18.10 kph) 95 mph (152.85 kph) | 83.13 mph (133.75 kph) | -11.87 mph (-19.10 kph) 100 mph (160.90 kph) | 87.50 mph (140.79 kph) | -12.50 mph (-20.11 kph) 105 mph (168.94 kph) | 91.88 mph (147.83 kph) | -13.12 mph (-21.11 kph) 110 mph (176.99 kph) | 96.25 mph (154.87 kph) | -13.75 mph (-22.12 kph) 115 mph (185.03 kph) | 100.63 mph (161.91 kph) | -14.37 mph (-23.13 kph) 120 mph (193.08 kph) | 105.00 mph (168.95 kph) | -15.00 mph (-24.13 kph) 125 mph (201.12 kph) | 109.38 mph (175.99 kph) | -15.62 mph (-25.14 kph) 130 mph (209.17 kph) | 113.75 mph (183.03 kph) | -16.25 mph (-26.14 kph) 135 mph (217.22 kph) | 118.13 mph (190.07 kph) | -16.87 mph (-27.15 kph) 140 mph (225.26 kph) | 122.50 mph (197.11 kph) | -17.50 mph (-28.15 kph) 145 mph (233.31 kph) | 126.88 mph (204.15 kph) | -18.12 mph (-29.16 kph) 150 mph (241.35 kph) | 131.25 mph (211.19 kph) | -18.75 mph (-30.16 kph) 155 mph (249.40 kph) | 135.63 mph (218.23 kph) | -19.37 mph (-31.17 kph) 160 mph (257.44 kph) | 140.00 mph (225.26 kph) | -20.00 mph (-32.18 kph) 165 mph (265.49 kph) | 144.38 mph (232.30 kph) | -20.62 mph (-33.18 kph) 170 mph (273.53 kph) | 148.75 mph (239.34 kph) | -21.25 mph (-34.19 kph) 175 mph (281.57 kph) | 153.13 mph (246.38 kph) | -21.87 mph (-35.19 kph) 180 mph (289.62 kph) | 157.50 mph (253.42 kph) | -22.50 mph (-36.20 kph) 185 mph (297.67 kph) | 161.88 mph (260.46 kph) | -23.12 mph (-37.20 kph) 190 mph (305.71 kph) | 166.25 mph (267.50 kph) | -23.75 mph (-38.21 kph) 195 mph (313.75 kph) | 170.63 mph (274.54 kph) | -24.37 mph (-39.21 kph) 200 mph (321.80 kph) | 175.00 mph (281.58 kph) | -25.00 mph (-40.22 kph)
If your speedometer has been calibrated for 205/75 R 15 (27 x 8.07 x 15) tires, replacing them with 267/76 R 15's (31 x 10.51 x 15's) would result in the speedometer reading low by 12.50%.
Odometer Error
Actual Mileage | Indicated Mileage with Tire B | Odometer Error 1 mi (1.61 km) | 0.88 mi (1.41 km) | -0.12 mi (-0.20 km) 5 mi (8.04 km) | 4.38 mi (7.04 km) | -0.62 mi (-1.01 km) 10 mi (16.09 km) | 8.75 mi (14.08 km) | -1.25 mi (-2.01 km) 50 mi (80.45 km) | 43.75 mi (70.40 km) | -6.25 mi (-10.05 km) 100 mi (160.90 km) | 87.50 mi (140.79 km) | -12.50 mi (-20.11 km) 500 mi (804.50 km) | 437.51 mi (703.95 km) | -62.49 mi (-100.55 km) 1000 mi (1609.00 km) | 875.02 mi (1407.91 km) | -124.98 mi (-201.09 km) 5000 mi (8045.00 km) | 4375.10 mi (7039.53 km) | -624.90 mi (-1005.47 km) 10000 mi (16090.00 km) | 8750.19 mi (14079.06 km) | -1249.81 mi (-2010.94 km) 50000 mi (80450.00 km) | 43750.96 mi (70395.29 km) | -6249.04 mi (-10054.71 km) 100000 mi (160900.00 km) | 87501.91 mi (140790.58 km) | -12498.09 mi (-20109.42 km)
Same as with the speedometer, if your odometer has been calibrated for 205/75 R 15 (27 x 8.07 x 15) tires, replacing them with 267/76 R 15's (31 x 10.51 x 15's) would result in the odometer reading low by 12.50%.
