Call all Isuzoo gurus..my tranny needs help bad! #769988 12/06/06 04:17 AM
mtbikerjohn Offline OP
Boy,I did it now! I need help..before the wife kicks my @*# for screwing up the Trooper..Here's what happened..while changing my tranny fluid/filter,I "broke" the terminal off of the 1-2/3-4 shift solenoid <img src="/forums/images/graemlins/confused.gif" alt="" /> I bought a replacement,put it all back together.Now I have only first gear..the tranny won't upshift..I checked the trouble code and got a "61-Gear Error" Yeah,no kidding! <img src="/forums/images/graemlins/lol.gif" alt="" /> Heres my question...Could I have gotten the wrong solenoid? the 1-2/3-4 solenoid and the 2-3 shift solenoid look identical..the manual says the difference is one is open normally,the other is closed normally...My tranny was fine until my "mishap",so I'm inclined to think that the problem lies there...Any ideas on what to look for,and fixing it? I'm wondering if I might have fried the TCM also....I did disconnect the TCM,to see if I could shift manually..alah,limp mode,but it still doesn't work...Help! ...TIA...John
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: mtbikerjohn] #769989 12/06/06 03:13 PM
BigSwede Offline
For something this technical I suggest you contact Jerry Lemond jlemond@bellsouth.net
He used to train Isuzu mechanics and is very helpful.
Serenity now!
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: BigSwede] #769990 12/06/06 04:42 PM
Thanks,BigSwede...I just wrote to Jerry,explaining my problem...Hopefully,Jerry will be able to steer me in the right direction....john
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: mtbikerjohn] #769991 12/06/06 04:49 PM
BigSwede Offline
No prob...also check out page 3 of this http://www.transtec.com/rebuilder_news/2nd_q95r-n.pdf
Lotsa tech info on the 4L30E...
Serenity now!
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: BigSwede] #769992 12/06/06 05:48 PM
I have that downloaded already..plus I bought a rebuild manual for the tranny...All I can think of is maybe the check balls aren't right,or I got the wrong solenoid sent to me...I hope Jerry can steer me in the right direction...Maybe it is time to change over to a 5 speed... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: mtbikerjohn] #769993 12/06/06 06:45 PM
BigSwede Offline
You are already way ahead of my knowledge of the guts of an auto tranny...I admire your sense of adventure <img src="/forums/images/graemlins/kewl.gif" alt="" />
As a side note, check out mwior.com since you are in the neighborhood.
Serenity now!
Re: Call all Isuzoo gurus..my tranny needs help bad! [Re: BigSwede] #769994 12/06/06 10:10 PM
not adventurous,just determined to "fix" my previous "fix"...I will check out the site you mentioned... <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 5.199s Queries: 15 (0.003s) Memory: 0.6138 MB (Peak: 0.6926 MB) Data Comp: Off Server Time: 2026-05-31 16:54:34 UTC
