2.6 pinging #770077 12/06/06 03:41 PM
camoraider87 Offline OP
Got a 87 Dodge Raider and it pings in 3rd 4th and 5th only if you dont get on it and drive normal want to know if any one else has had this problem
paved roads a fine example of needless goverment spending
87 Dodge Raider
Re: 2.6 pinging [Re: camoraider87] #770078 12/06/06 05:10 PM
Loosing any coolant? Mine did that right before the head gasket went. Also a sign of a sticky vac or centrif advance in the dizzy. How is the power?
Re: 2.6 pinging [Re: fasteddy] #770079 12/06/06 05:53 PM
powerRam50 Offline
as said it could be the distributer.also you need to check your timing.it sjould be 7* btdc give or take 2*.if you are at 9 then back it off to 7 or if you are at 7 back it off to 5.at 9* my truck will ping but it is fine at 7.
Re: 2.6 pinging [Re: camoraider87] #770080 12/06/06 07:17 PM
conner Offline
Ck EGR system operation.
Conner
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: 2.6 pinging [Re: fasteddy] #770081 12/06/06 09:20 PM
not looseing any coolant head just been done not to long ago new o2 senser
87 Dodge Raider
Re: 2.6 pinging [Re: conner] #770082 12/06/06 09:22 PM
have not checked timeing or egr
87 Dodge Raider
Re: 2.6 pinging [Re: camoraider87] #770083 12/06/06 10:17 PM
dadrab Offline
You'll need to follow the advise above, but you should start running higher octane gas too. At about 75,000 miles, my NA engine started pinging exactly as yours is. I checked timing and replaced dist. cap, rotor, plugs and wires to no avail.
Finally, someone suggested I fill-up with 93 octane gas. Never pinged a ping after that unless I went back to 87.
with awesome audio.
Re: 2.6 pinging [Re: dadrab] #770084 12/06/06 10:24 PM
Angel Carlo Offline
I have a Ford Asspire lol, that also pings unless I use 93octane. I checked the timing but can't rely on that because someone may have changed the timing belt and was off a few teeth. As long as I use high test, it's fine. Better power too for a 1.3L. They may have advanced the timing for that reason. Little thing has no hp stock. I figure they squeezed out some more by advancing the timimg.
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: 2.6 pinging [Re: dadrab] #770085 12/06/06 10:40 PM
I got new plugs, wires, dist.cap,rotor,to but ill try higher octane gas wont hurt nothing but my pocket <img src="/forums/images/graemlins/lol.gif" alt="" />
87 Dodge Raider
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6247 MB (Peak: 0.7114 MB) Data Comp: Off Server Time: 2026-06-10 14:04:45 UTC
