What Am I?????
#770086
12/06/06 04:09 PM
OK I don't know what this part is, and thought someone on here might, so here it is... It has two vacuum hoses on it, and I think two gas lines, but I am not sure...Only one vacuum hose is on it, the other one broke off... Thanks, Matt
Gas vapor collection...
[Re: SuperSwamper]
#770087
12/06/06 04:29 PM
I believe it is vapor collector for your fuel tank. Chock full of carbon, with the vapors eventually routed via the vacuum hoses to the intake. I think I first saw one on my `82 Chevy P/U...
Re: Gas vapor collection...
[Re: Mulerider]
#770088
12/06/06 06:49 PM
yup, its the charcoal canister.
-Rob
[Re: RobG]
#770089
12/07/06 02:04 AM
And all this time I thought that was where the headlight fluid goes! Sheesh <img src="/forums/images/graemlins/wink.gif" alt="" />
[Re: Fujisawa_Rob]
#770090
12/07/06 05:29 AM
ok, thanks, and I was wondering is it going to be a problem that the one vacuum hose broke off???? Matt
[Re: SuperSwamper]
#770091
12/07/06 06:07 AM
ok, thanks, and I was wondering is it going to be a problem that the one vacuum hose broke off???? Matt no. . .just replace it. <img src="/forums/images/graemlins/wink.gif" alt="" /> (the other end is the vacuum source, and you thus have a vacuum leak, which isn't generally a good thing) //bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
[Re: trooperbc]
#770092
12/08/06 04:18 PM
Ok, Thanks I guess I need to add that to the list of things to get... Matt
[Re: SuperSwamper]
#770093
12/09/06 04:41 AM
...add that to the list of things to get... Matt well, sorry, didn't mean to give you the idea to just let it go with my flip response. you should take care of any vacuum leak as soon as possible. and you want that cannister system to work -- both for our environment and so that you and your passengers are not getting overwhelmed possibly with fuel fumes. //bc
[Re: trooperbc]
#770094
12/09/06 10:53 PM
that's ok, I knew I needed to replace it, just didn't know what it was, I would just replace the hose, but the piece it attaches to on the canister, broke off.... and the whole trooper is a project, so no big deal... Matt
[Re: SuperSwamper]
#770095
12/10/06 01:07 AM
ok. but in the mean time, if you are driving it, plug that vacuum leak, i suggest. replace the hose and plug it, or cap the vacuum port.
//bc
