Computer Location on 98 Rodeo #770150 12/07/06 01:45 AM
trav Offline OP
Hey. i am doing some work on the frame and need to do some welding. Does anyone know how to disconnect the computer so it doesn't get fried? or do i even need to? Thanks again guys!!!
Trav
1998 Isuzu Rodeo -- slightly modified.
Re: Computer Location on 98 Rodeo [Re: trav] #770151 12/07/06 04:20 AM
mlclark Offline
Isuzu Moderator
Either unplug it and unbolt it from the vehicle (it grounds through the case, or should.
Or pull the battery. That should be sufficent in most cases.
Michael
Re: Computer Location on 98 Rodeo [Re: trav] #770152 12/07/06 12:49 PM
Bansil Offline
I have always just disconnected the battery,and I have welded alot on our 98 frame.
The computer is located on the floor in front of the console under the dash,unless you had the factory cd changer,then it will be on the passenger fender liner.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5902 MB (Peak: 0.6433 MB) Data Comp: Off Server Time: 2026-07-16 05:31:06 UTC
