Re: igniter [Re: jello] #770186 12/08/06 06:51 AM
Z
zachtheterrible Offline
What kinda vehicle is the igniter that you have from? I believe that a lot of them can be re-wired
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: igniter [Re: jello] #770187 12/08/06 09:18 PM
dcg9381 Offline
is it posible to wire this direct without shorting it out.
i changed the truck from 2wd auto to 4wd 5 speed it had no igniter
If it's EFI, it's got an igniter... The only exception might be an early Celica, which had EFI but a vac advance distributor. Have a photo of your engine bay?
It's possible to fire the coil directly if you've got a non-EFI vehicle, yes.
If you've got an EFI vehicle, you'd need both - you need to provide the ECU information about RPM and timing (via the ignitor). If you left the ignitor in there, I suppose you could patch in another type of ignition system - such as a mechanical system with vac advance. I wouldn't recommend it unless you understand what you're doing.
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5924 MB (Peak: 0.6408 MB) Data Comp: Off Server Time: 2026-06-07 09:53:58 UTC
