Another Instrument Cluster Question #770213 12/07/06 04:59 AM
Smoke Offline OP
Can anyone tell me if the 94 Toyota Pick Up DLX and the 94 4 Runner SR5 have the same wiring harness arangement at the instrunent cluster? I have the pick up manuals but nothing from the 4 Runner to compare it to!! Otherwise I'm wanting to replace my instrument panel without tach and gauges with one from a 4 Runner SR5 same year, both 4X4 and automatic. Pretty sure I'll have to run the tach wire and know about the changing the oil pressure sending unit but was wondering if there would be any other surprises. Could find nothing in the search about the later model swaps!
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: Another Instrument Cluster Question [Re: Smoke] #770214 12/07/06 05:53 AM
OOP'S Offline
On my 90 the tach wire was already there. I cut it loose from the connector and used it to fire my aftermarket tach. Worked fine until I must have pulled it apart in the dash. To get to it I have to take the cage out so I rewired it to the tach test connector under the hood.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Another Instrument Cluster Question [Re: OOP'S] #770215 12/07/06 01:29 PM
Smoke Offline OP
Thanks for the reply!!
Re: Another Instrument Cluster Question [Re: Smoke] #770216 12/11/06 12:51 AM
I have a 92 4x4 dlx and recently put a instrument cluster from a SR5 as I wanted the tach and guages. I bought one from a 92 that had the v6 even though mine has the 4 cyl. It bolted right in and having bought a oil pressure sending unit all the guages worked great! All the wiring was set for the tach, volts and all the lights. The only caution I know of is to buy the oil pressure sending unit as if you hook up the cluster with the oil pressure gauge it will burn out the gauge so you must disconnect the pressure wire before installing the new cluster.
Enjoy.
Craig
Re: Another Instrument Cluster Question #770217 12/12/06 02:25 AM
Smoke Offline OP
Gottcha!! Thanks for the reply!!
Re: Another Instrument Cluster Question [Re: OOP'S] #770218 12/15/06 08:15 PM
IceBlueT Offline
I have an autometer monster tach that i was given and i want to put it in my truck. which connector and where is it that i hook the tach to?
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: Another Instrument Cluster Question [Re: IceBlueT] #770219 12/15/06 09:22 PM
OOP'S Offline
Here you go!!!!
David Fritzsche
Roseville, CA
Re: Another Instrument Cluster Question [Re: OOP'S] #770220 12/19/06 08:19 PM
IceBlueT Offline
thanks! should be in by new years eve! (if i get the time off from work)
<img src="/forums/images/graemlins/angry.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6216 MB (Peak: 0.7167 MB) Data Comp: Off Server Time: 2026-06-07 10:01:53 UTC
