Gen II front bumper removal #770545 12/08/06 07:43 PM
Robb Offline OP
Im usually pretty good at taking stuff apart, but this front bumper has me lost. Can some explain where to begin in getting this whole contraption off, I want to start from scratch and make my own. Thanks!
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: Gen II front bumper removal [Re: Robb] #770546 12/08/06 07:50 PM
Alex Kogan Offline
Take front skid plat off. Remove 4 bolt holding bumper to frame horns (2 each side). Remove bumper. <img src="/forums/images/graemlins/patriot.gif" alt="" />
08 PowerWagon (stock!)
Re: Gen II front bumper removal [Re: Alex Kogan] #770547 12/08/06 08:07 PM
Robb Offline OP
Thank you sir! <img src="/forums/images/graemlins/kewl.gif" alt="" />
-Robb
1992 Montero (pics)
Re: Gen II front bumper removal [Re: Robb] #770548 12/09/06 02:13 AM
Scottie2113 Offline
yeah, the 4 bolts are kinda up underneath behind the bumper, long bolts like 5 or 6 inches long. the nuts are tig welded to bumper, if bolts are very rusty, it is possible to break the tig welds and be spinning the bolt for 30 minutes before you realize it aint comin out without holding that nut that I broke the tig welds off. that is what happened when i took mine off my SR
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6011 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-23 22:36:24 UTC
