Gen II aftermarket wheels
#770549
12/08/06 08:16 PM
I tried searching this a 100 different ways as im sure its been covered. I have 31x10.5x15 tires now on the stock wheels. The truck looks awfully tall and skinny. I want to some wider wheels im assuming 15x8, but im lost when it comes to backspacing and offset. I plan to upgrade to a 33in tires in the future and would like a wheel i can use with a bigger tire as well. My truck is the bottom of the line with no fender flares and I dont plan to go there. I do want the tire to stick out some. I plan to just get some cheap black wheels from summit or something. Offset/backspace suggestions needed! (maybe some pictures) Thank you!
Re: Gen II aftermarket wheels
[Re: Robb]
#770550
12/08/06 08:50 PM
Hi Robb, For reference there are a couple of pics of my maroon '97 LS with 32s here and here. The rims are 15x8 with 3.75" backspacing. The tires stick out a bit, which me likey. check it out and see if that's what you want. Good luck.
[Re: Mad_Scientist]
#770551
12/08/06 09:33 PM
Thanks for the post, thats about exactly what I am looking for, is this the backspacing most people are running?
[Re: Robb]
#770552
12/08/06 09:46 PM
I think so, but I suspect there are all kinds of combinations running out there. Although I think ChrisJ said he was running 4"BS. His Raider is in the same thread. PM him to make sure.
[Re: Mad_Scientist]
#770553
12/08/06 10:19 PM
OK, I think I am going to go with this wheel from Summit: I only have the options of a 4 inch backspace and a 4.75 inch back space. How will the 4 inch backspace compare to your 3.75 inch back space, will this stick out farther, or sit in the wheel well more? Here are the specs: Rim Diameter (in): 15 in. Rim Width (in): 8.00 in. Backspacing (in): 4.000 in. Offset (mm): -12.00mm 6 x 5.5 in bolt pattern
[Re: Robb]
#770554
12/08/06 10:56 PM
That's the same wheel I'm running on my Gen I. It will be in the wheel well farther by 1/4". I think you'll like them, though because they'll stick out ~3/4" over stock.
HTH
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
[Re: Oyaji_Jon]
#770555
12/09/06 01:34 AM
I have these wheels on my GenII 1991 JDM Pajero. they are Identical even down to the centre cap, and im sure they are way cheaper too. I have 16X8. ![[Linked Image]](http://www.discounttiredirect.com/product/wheels/uni297.b.xl.jpg)
[Re: torquemonster]
#770556
12/09/06 01:53 AM
Where did you get those? The wheels from summit are 36.99 each.
[Re: Robb]
#770557
12/09/06 06:09 AM
Unique is made by the same maker for Crager rims IIRC.
[Re: off-roader]
#770558
12/09/06 11:51 AM
well then that would explain why they are are the identical rim then haha.
