Re: 87 Raider will not start... ideas??? (Please help,'cuz I'm not too bright!) [Re: Robb] #770963 12/19/06 08:14 PM
BobShaw Offline
I had a similar problem with my 87 starting. I replaced the starter and it worked for awhile then quit again. It was in the small wire circuit that puts power to the starter solenoid. I was getting less than 6 volts. Run a wire from the battery to the small contact on the starter solenoid and see if it clicks or cranks (no key required).
I ended up putting a relay in the circuit and using the 6 volt starter wire to energize the relay.
Re: 87 Raider will not start... ideas??? (Please help,'cuz I'm not too bright!) [Re: BobShaw] #770964 12/21/06 01:23 AM
Bob, did you check for voltage drop across the switch? Mitsu ign elec. switch comes off the lock part with two screws, and is readily replacable...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5948 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-06-15 10:24:10 UTC
