Is this a pic of a fubar'd axle? #771100 12/10/06 07:22 PM
The_Rusty_Gear Offline OP
Drivers side stub axle. It didn't want to go back into the diff tube so I started "tapping" it with Mr. Smashy. Didn't seem to work. Took the axle out and I'm not sure if it was like this before or if my tapping caused it.
Can I sand down the ridges and re-install, or should I go and get a new axle?
1988 4Runner, V6 Auto, Mostly Stock
32 x 9.5 Swampers
Re: Is this a pic of a fubar'd axle? [Re: The_Rusty_Gear] #771101 12/10/06 11:00 PM
A
allochris Offline
personaly, i won't worry about it. just sand the end smooth & make sure it goes in smoothly next time you tap it in. I don't think the end of the axle serve any purpose anyway, just make sure your splines are in good condition though...
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Is this a pic of a fubar'd axle? [Re: allochris] #771102 12/11/06 12:57 AM
Jeffstoyo Offline
I agree, should be fine, just file the splines at the ends so it will fit in the spider gears.... I find that if I rotate the driveline slightly when installing the front axle shafts, it helps line it all up.
Jeff S.
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Is this a pic of a fubar'd axle? [Re: The_Rusty_Gear] #771103 12/11/06 08:33 AM
rednekbean Offline
i would cheak for bent axle and or axle housing. happened to my buddy, had a bent axle and axle tube, prolly from stump jumping it at the dunes and up the logging trails. it came out easy and well never went back in, and yes Mr.smashy was happy when put away that day.
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
PHP: 7.4.33 Page Time: 1.189s Queries: 15 (0.005s) Memory: 0.6005 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-06-04 11:00:06 UTC
