What are the bad years of cherokee? #771261 12/11/06 05:53 AM
I'm looking to buy a Cherokee for my hunting and off-road rig. Which years do I want to stay away from and which years are prefered for reasons such as power plant, transmission and diffs? Any input would be helpful.
Robert
Re: What are the bad years of cherokee? #771262 12/11/06 06:52 AM
Berkeley Offline
Jeep Moderator
Absolutely do not get a 2.8L V6. I can't imagine there are any still running, but you never know. They were only available for the first few years (84-86). Other than that, the newer the better! Personally, I'd go 4.0L HO I6 auto-trans '91-'97.
Re: What are the bad years of cherokee? [Re: Berkeley] #771263 12/11/06 04:58 PM
Thanks for the info
Re: What are the bad years of cherokee? #771264 12/11/06 05:36 PM
Seattlegti Offline
Some came with a Pugeot 5 speed manual. I'd avoid them. My sisters XJ unfortunatly came with one, she's on her third transmission at 200K.
I have a 91 and a 98 with the HO 6 cyl and auto trans, never had any mechanical problems with either.
Re: What are the bad years of cherokee? [Re: Seattlegti] #771265 12/12/06 09:37 PM
Brown81CJ5 Offline
That sucks! Sounds like a ford. The diesels are ok, but the others suck.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: What are the bad years of cherokee? [Re: Brown81CJ5] #771266 12/12/06 09:44 PM
BigJim Offline
Lots and lots of Stangs had the very same Pugeot tranny in them. Many of them get 200K without any problems.. They seem to be a bit weak for dome of the trails guys put em on.
Re: What are the bad years of cherokee? [Re: BigJim] #771267 12/13/06 06:01 PM
mmcpeck Offline
I have been looking at the newer (90's) models as well, can't find any bad comments about any of them. I have an '87 with the 4.0 and automatic, 165K on original drivetrain. Tranny shifts tight, no slip at all, and engine purs no problem, sometimes a little rough at idle, still pretty quick actually too. So it's made me a believer in these trucks.
Berkely....I actually have seen one 2.8 that is still running, I don't know how well it runs, but it moves everyday. I see it on my walk home everyday in a different spot on the street (Manhattan), it is beat to hell, doesn't even have a grill on it anymore, but that guy moves that thing to a different spot everyday.
Re: What are the bad years of cherokee? [Re: mmcpeck] #771268 12/14/06 05:33 AM
cuervo25 Offline
nothing newer than 98,they had head problems. the castings was weaker and the don't flow as good.
Re: What are the bad years of cherokee? [Re: cuervo25] #771269 12/14/06 05:40 PM
Bigbird79 Offline
I have heard a lot of comments on here about the 99+ 4.0 heads being bad, seeing that I have a 99 this has definitely grabbed my interest. What specifically are the differences, between the 99+ and the pre 99? And how do the problems with the 99+ manifest themselves? Are the 99+ really that bad that I should start looking for a replacement earlier unit for when mine fails? Also how do I identify the difference in the heads? I did some searching on the net and all I can find is the Part number for the head changed from 0630 to 0331 mid 1999, so I am thinking I could be OK, but I could have a problem, and I would just like to identify what I actually have. I havenÆt really found any good sites that detail out the issues.
Thanks,
Sean
Re: What are the bad years of cherokee? [Re: Bigbird79] #771270 12/14/06 05:51 PM
Seattlegti Offline
http://www.opiebennett.com/tech.htm
This site has some useful information on Cherokees. Haven't heard much aboth the 99 up models having a weak engine.
As with any Jeep regular maintence and fluid changes are the best way to keep it running. My old beat up 91 XJ has over 300,000 miles on the origional motor and trans and still runs like a top. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6360 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-05-29 16:23:32 UTC
