Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: Electric fan installation [Re: Airdale73013] #771376 03/03/07 04:03 AM
Hydra747 Offline
You found the thread! <img src="/forums/images/graemlins/patriot.gif" alt="" /> I bought the electric fan and it is still sitting on my treadmill in the box. Will attempt to work on it before the HOT SUMMER <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Electric fan installation [Re: Hydra747] #771377 03/07/07 02:32 PM
Hydra747 Offline
I'm looking for a SPAL and I can't find one <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Electric fan installation [Re: Hydra747] #771378 03/07/07 03:54 PM
A
Airdale73013 Offline OP
I purchased my Spal controller from www.wizardautomotive.com for $79.95 + $10.00 shipping.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Electric fan installation [Re: Airdale73013] #771379 03/07/07 04:00 PM
Hydra747 Offline
Thank You, Thank You and Thanks! Will check it out ASAP! Will PM u for further.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
I also bought the Belt. Now I guess I have to get the nerve now <img src="/forums/images/graemlins/lol.gif" alt="" />
How is the new fan still holding up?
Any new Pics??????????
Thanks again <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Electric fan installation [Re: Hydra747] #771380 03/07/07 04:22 PM
A
The new fan and controller work great.
Oddly though a few days ago on the way home from work at 70 mph my check-engine-light came on, did not give it much thought, and then a couple of seconds later my air-bag lamp came on and then started flashing. I began to get concerened at that point and exited the turnpike and had to stop at a stop light, so I decided to shut down the engine and re-start it to reset everything, BIG MISTAKE, well the engine would not turn over.
A Highway Patrol car was behind me and gave me a push around the corner to get off the road and fortunately it was down hill and I was able to get the car started and limped the 1.5 miles to my home at about 5 mph sputtering all the way.
The alternator had died and looking bach had probably been intermittent for several weeks. Went to OReily's and picked up a reman unit for $122.00 and the problem was solved.
My new fan worked through all that and the car did not over-heat.
I will say the the Sporty got me home and did not leave me stranded, and considering that the battery voltage was only 6.5 vdc when I got home it is amazing that the sportage would run at all.
Re: Electric fan installation [Re: Airdale73013] #771381 03/08/07 08:10 AM
Everet Offline
I used a Cooper C7220 which is a pocket thermometer used by A/C folks, it has a 5" stainless steel probe and reads form 0 to 220 deg F. I just stuck the probe in the radiator tank, dissconnected the power to the fan, set the low set point at 160 F and the high set at 200 F. The fan will run at 50% all the time with a warm engine unless the temp goes above 200%. Of corse the fan runs at 100% any time the A/C is on. I did connect the A/C input to the Spal to the + fan connection which is on as long as the A/C is on.
Can you set the SPAL to run @ 185 w/50% and 200 @ 100%. I see no reason for it to kick on below 185f.
Thanks, Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Electric fan installation [Re: Everet] #771382 03/08/07 02:04 PM
A
You can set both the low (50%) and the high (100%) independently. So the answer is yes. The reason for setting the low at 160 deg is to establish air-flow through the radiator before the thermostat opens.
Re: Electric fan installation [Re: Airdale73013] #771383 03/23/07 01:01 AM
catman25 Offline
bought the fan and spal combo,I have a couple of questions...
1)do you want the fan to push or pull...Pull air from outside passed ac the radiator?
2) I dont have a temp reader..At what level on the standard oem temp gauge is 160 and 200? With clutch fan my temps dont raise past half,Actually little below half.
3) The temp sensor?Do you reroute wire or slice it?totally disconect or must the wire stay intact ?
4) did you remove radiator for this mod?
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: Electric fan installation [Re: catman25] #771384 03/23/07 05:23 AM
Lennyburger Offline
In answering the first question, always pull the air from the front of the radiator and A/C condenser, that way you get cool air from outside the vehicle, not hot engine bay air, and also if you tried blowing it out through the front you'd be fighting the air trying to get in whilst the car travels along. <img src="/forums/images/graemlins/cheers.gif" alt="" />
KIA, More dirt for ya dollar! 99 Sportage, Pod filter, Bosch Super4 plugs, electric thermo fan, racing pedals, Narva 100W driving lights, Yokhama 235/75R15 Super Diggers....getting to the rest bit by bit.
Re: Electric fan installation [Re: Lennyburger] #771385 03/24/07 01:45 PM
Delarey Offline
OK now let me also jump onto the bandwagon. Just below the thermostat housing there are two connectors. The left side one has got two wires and the right has one. I think the left one is the temp sensor, but what is the one on the right? Can one use one of these to connect to the fan to come on when it is necessary? The fan does not have to grind along all the time even at half speed?
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6505 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-06-07 05:46:35 UTC
