Re: Electric fan installation
[Re: Nukeiridium]
#771366
12/24/06 04:46 PM
Where did you buy the SPAL and how much $? Thanks, Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Everet]
#771367
12/24/06 10:42 PM
I bought it on Ebay for $65
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
[Re: Nukeiridium]
#771368
12/26/06 02:51 PM
Do u know if it is the same one airdale used? And did u keep the a/c fan??????
[Re: Hydra747]
#771369
12/26/06 07:41 PM
The controller is the same one Airdale used but I used a different fan.
I didn't take off the stock AC fan yet but I probably will. I didn't have time. Also it is very cold right now, I won't be using AC for a while so there is no rush to work on that kind of thing.
[Re: Nukeiridium]
#771370
12/27/06 03:00 PM
Nope I used the Procomp 16" purchased on ebay also.
2009 Sorento LX, 4x4, V6, Auto, Red
[Re: Airdale73013]
#771371
12/27/06 04:13 PM
Nope I used the Procomp 16" purchased on ebay also. No u did or did not? Im guessing that u have the same fan right? Well, I am going to place my order prolly today and of course work out all of the nuances and such <img src="/forums/images/graemlins/smile.gif" alt="" /> What are the special wrapping issues/tricks for sealing real well etc....I could use all the advice given with this area <img src="/forums/images/graemlins/confused.gif" alt="" />. Thanks a billion <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Hydra747]
#771372
12/27/06 05:14 PM
Yes I installed the Procomp 16" the very same fan.
[Re: Airdale73013]
#771373
12/27/06 08:16 PM
HAHA cool! So we have twin setups! Hehehe...
Dude the spal rocks but one thing I wish I had... was an easy way to get the engine temp reading so I could set my Spal to 160 degrees low and 200 degrees high. I had to estimate.
I have an OBDII tool that will tell me the engine temp but it's a huge hassle to hook it up, because it requires a computer and I don't have a laptop <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: Nukeiridium]
#771374
12/27/06 10:01 PM
I used a Cooper C7220 which is a pocket thermometer used by A/C folks, it has a 5" stainless steel probe and reads form 0 to 220 deg F. I just stuck the probe in the radiator tank, dissconnected the power to the fan, set the low set point at 160 F and the high set at 200 F. The fan will run at 50% all the time with a warm engine unless the temp goes above 200%. Of corse the fan runs at 100% any time the A/C is on. I did connect the A/C input to the Spal to the + fan connection which is on as long as the A/C is on.
[Re: Airdale73013]
#771375
03/02/07 08:48 PM
This is the electric fan installation from that guy in Oklahoma. <img src="/forums/images/graemlins/smile.gif" alt="" />
