Page 2 of 4 1 2 3 4
Re: Growling rear end [Re: wsquaredodie] #771642 12/13/06 08:21 PM
Don Tibbetts Offline OP
Another spot to look is the carrier bearing. The 2 piece drive shaft is cradled in the middle at the u-joint by a rubber suspended bearing. These things are right out in the slop when you are driving and make one heck of a growl when dried out. Most factory carrier bearings are not provided with a grease joint so they eventually dry out the factory lube and go to pot.
My bet would be the carrier bearing..
This was my original suspicion because I can move the driveshaft a good bit in any direction when I push on it but that doesn't really have anything to do with the bearing itself, just the rubber. I'll give this a listen tonight when I've got it jacked up and spinning to see if I can discern any noise or excessive movement.
97 T100 4WD SR5 - 231K
Re: Growling rear end [Re: Don Tibbetts] #771643 12/13/06 09:36 PM
Jake97T Offline
it will move a bit, i made the mistake of replacing the support bearing, didnt need to, ended up being the wheel bearing...
Re: Growling rear end [Re: Jake97T] #771644 12/13/06 10:17 PM
That's why I hesitated to pull the trigger on a $110 part that may or may not solve my problem.
Re: Growling rear end [Re: Don Tibbetts] #771645 12/15/06 05:59 PM
Honger Offline
I just want to pipe in with another supportive opinion leaning toward the wheel bearing. They make a pretty discouraging growling noise tht gets worse over time. I was shocked at how much quieter things were after replacing that bearing.
Joel
1998 Toyota T100 SR5 ExtraCab 4WD
Re: Growling rear end [Re: Don Tibbetts] #771646 12/15/06 11:14 PM
wsquaredodie Offline
Did not realize the wheel bearings are sealed. Thanks for guys like Eric. But the test still is valid. Loading one side and then the other to see if noise is increased is the simplest test for them, gear lubed or not.
trafdlo
Re: Growling rear end [Re: wsquaredodie] #771647 02/08/07 05:37 AM
Ridiculously late follow up. The rear wheel bearings appear to be fine. I changed the rearmost u-joint and it cured the growling noise. I do still have a strange wobbling sound coming from the driveline but it comes and goes, its not steady like the growling sound was. I'm going to change that center support bearing and go from there. I just need to get around to ordering it.
Re: Growling rear end [Re: Don Tibbetts] #771648 02/08/07 08:01 AM
4
4xGeek Offline
I too have an odd wobble in the driveline that comes & goes... Been struggling to figure out what the hell it is for forever; keep chasing it from front to back, side to side - never consistent enough to determine... <img src="/forums/images/graemlins/angry.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Growling rear end [Re: 4xGeek] #771649 02/08/07 09:20 AM
kewlynx Offline
Take your driveline in to be balanced, or find a mechanic who can check the runout.
I wallowed out one of my older Toys a few years back; rebuilt the pumpkin. 4 months later, came back, WTH? Friend of mine had a runout gauge; found that at some point I had bent the D/L. Took it into a D/L shop; got it balanced; has been okay since.
If ya got any lift, double check yer angles.
**ubi apis- ibi salus**
Re: Growling rear end [Re: kewlynx] #771650 02/08/07 06:04 PM
Jake97T Offline
4xGeek, long time to see...
could a driveline cause lurching while stopping, cant feel any shutter in the brake pedal from warped rotors... <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Growling rear end [Re: Don Tibbetts] #771651 02/09/07 02:34 AM
Hackattack Offline
I have a 95 T100 4x4 xtracab and have all these problems. It has been cold here in Cincinnati and in the morning when I first take off I get the growling - vibration for the first mile or so then it goes away. It seems to be worse when turning right. It never does this after a mile or so. I also have the come and go shakes on the highway. I am not a mechanic so this truck is driving me nuts & to the poor house. Does anyone know what a 95 T with 146,000 on it is worth?
Toyota T100 best truck Toyota ever built "Its so good the frame does not rust in half"
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6414 MB (Peak: 0.7489 MB) Data Comp: Off Server Time: 2026-06-17 05:20:42 UTC
