Page 4 of 4 1 2 3 4
Re: Growling rear end [Re: 4xGeek] #771662 03/03/07 04:42 PM
adam Offline
I can buy that. Just wasn't what I ran into when mine went out. Maybe I just didn't let them get so bad before I had them replaced. The explanation I got on the load and unload forces of the ring and pinion and those bearings at the time lined out more of a straightforward all the time growl out of the axle bearings and a side-side growl out of the carrier bearings.
In any event, you gotta dig your way in from the outside. I didn't mean he should ignore the outers on the way in for sure. <img src="/forums/images/graemlins/cheers.gif" alt="" />
~Adam
Re: Growling rear end [Re: adam] #771663 03/03/07 05:18 PM
ErikB Offline
Toyota Moderator
The other thing that usually happens when a wheel bearing wears out is you get an oil leak into the brake drum. I'd think you would have noticed that though...?
http://home.4x4wire.com/erik
Re: Growling rear end [Re: ErikB] #771664 03/03/07 06:35 PM
Sneaky_Snapper Offline
I am anxious to hear the result of this thread since my truck has that infamous growl also--it has 100,000 miles on it.
Thanks, Brad
1997 T100 SR5, X-Cab, V-6, Auto, 113,000 miles, Bilstein shocks
Re: Growling rear end [Re: ErikB] #771665 03/04/07 10:15 AM
4
4xGeek Offline
But that's usually once the seal has been cooked... Could be still intact (for now).
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: Growling rear end [Re: Don Tibbetts] #771666 03/28/07 05:02 AM
Did you ever get your growling problem repaired? Thanks, Brad
Mine was the rear wheel bearing with a leak from the seal.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6134 MB (Peak: 0.6774 MB) Data Comp: Off Server Time: 2026-06-20 18:58:47 UTC
