Re: Turning off ABS warning light [Re: 4Play] #771916 12/22/06 08:02 PM
holger Offline
I also have the ISC warning light on too.
Ashby, I know how to turn the ISC warning off. You need just pull the ISC fuse out of the electric box under the hood at the passenger side. I did it on my Axiom when I was removing the ISC shocks. No warning, everything is clear.
As for the ABS, may be the same way is applicable to the ABS lights. Find the ABS fuse, try to remove it and see how it works. But do this on your own risk.
Oleg
Deceased Rodeo'02 4WD.
Re: Turning off ABS warning light [Re: Bigpoppax2] #771917 12/23/06 03:47 AM
henry44 Offline OP
I am going to use a old proportioning valve off an older trooper that has two inputs and front and a rear and then it has two outputs for the front brakes and one for the rear. This has the correct fittings and everything to be able to remove your ABS pump completely.
Tad already did this on his 94 Trooper and said it made a big difference in his braking performance.
Joe
Do you have a year range for the proportioning valve? This sounds like something I want to know more about.
Thanks
Henry
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5957 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-06-07 08:03:24 UTC
