Spongy brakes
#772024
12/14/06 06:08 AM
Have a 1993 Trooper thatall of a sudden the brake pedal seems spongy and doesn't stop well. Acts like the front brakes no longer work? Fluid level is still up and have done no work to brakes to permit air in system. I did hit the brakes hard while hunting but can't remember if the problem started then. Is it possible tohave "flipped" the cup in the master cyl. by braking hard? Any help would be greatly appreciated. Thanks! Gary
Re: Spongy brakes
[Re: Rhino58]
#772025
12/14/06 10:10 AM
Probably a stuck piston in the master cylinder. When's the last time you flushed your brake fluid? You should be doing it once a year or more if you play in the water with your truck. Air isn't the only thing that can get into your brake lines. Brake fluid readily absorbs water vapor right out of the air. This can cause your master cylinder parts to corrode and possible allow the piston to get stuck in the bore, which is what I believe may have happened here.
I wouldn't bother trying to fix a master cylinder. Just get a new one, bench bleed it very well and flush the rest of the old fluid from the system.
KG6VNX
Re: Spongy brakes
[Re: Rhino58]
#772026
12/14/06 06:17 PM
Have a 1993 Trooper thatall of a sudden the brake pedal seems spongy and doesn't stop well. Acts like the front brakes no longer work? Fluid level is still up and have done no work to brakes to permit air in system. I did hit the brakes hard while hunting but can't remember if the problem started then. Is it possible tohave "flipped" the cup in the master cyl. by braking hard? Any help would be greatly appreciated. Thanks! Gary MC could be leaking internally. Definitely not worth rebuilding, especially since you can't hone an aluminum MC like you can with cast iron.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5912 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-06-24 14:46:56 UTCValid HTML 5 and Valid CSS
