1.0 Kw starter motor. #772108 12/14/06 04:36 PM
dcs14 Offline OP
I recently replaced my started motor with a re-manufactured one from Toy.
My Toy manual identifies 1.0 Kw and 1.4 Kw versions. I can detect no markings on the physical starter indicating which version it is.
Since 4x4s sometimes have a heavier duty application I asked Toy about this when I purchased mine. Their reply was that most applications took the 1.0 Kw version and that the 1.4 Kw version was for cold application, like for example Canada.
Since my recently installed 1.0 Kw version seemed like it had about 90% of the vigor of the one I removed, it started me to wonder.
Any comments out there to put my wondering to rest?
Re: 1.0 Kw starter motor. [Re: dcs14] #772109 12/14/06 04:39 PM
dcs14 Offline OP
Oh yes, this is an 85, 22RE with an automatic.
Re: 1.0 Kw starter motor. [Re: dcs14] #772110 12/14/06 05:23 PM
ErikB Offline
Toyota Moderator
I dunno. I noticed the reman I bought from Toyota seemed less powerful as well. Works ok though.
I know from over on the T100 forum that the T100's came with 1.2, 1.4, and 1.8kw starters, FWIW, and its pretty tough to tell which one you have unless you compare part numbers.
http://home.4x4wire.com/erik
Re: 1.0 Kw starter motor. [Re: dcs14] #772111 12/14/06 06:35 PM
stock87 Offline
Actually, from what I've been able to tell, automatics got the 1.4, since they have to spin the torque converter, and a slightly heavier duty alternator too.
I've done some part cross-referencing, and it seems like all autos got the 1.4kW starter, and autos from the years around 1989-91 got 70amp (vs. the usual 60/65) alternators.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 1.0 Kw starter motor. [Re: stock87] #772112 12/14/06 06:39 PM
4Crawler Offline
Another good reason to try and repair the starter you have rather than take a chance on a re-man unit:
- http://www.4crawler.com/4x4/CheapTricks/Starter.shtml#Fix
Re: 1.0 Kw starter motor. [Re: 4Crawler] #772113 12/17/06 04:36 AM
904runner2dr Offline
I always sold the 1.4 when I worked for Toyota.I was told it depended on the area you live in.If it's a cold climate or not.If you have the original starter the part number should be on the sticker if you can read it.It will start with a 28100-xxxxx.
Re: 1.0 Kw starter motor. [Re: dcs14] #772114 12/18/06 03:58 AM
kewlynx Offline
Note my location; I stick with the 1.4kw I think it just does a better job of tossin' that flywheel when everything has been cold soaked.
Both the 1.0 and 1.4 are available anywhere; after that it's a price preference.
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6193 MB (Peak: 0.7103 MB) Data Comp: Off Server Time: 2026-06-10 10:24:32 UTC
