Page 1 of 4 1 2 3 4
IFS shaft replacement #772652 12/16/06 08:03 PM
thefreqofnature Offline OP
I have an 88 4Runner IFS. I just noticed the drivers side inboard boot is cut. I've seen a write up on replacing these but I can not find it. The write up included a mod so next time the hub doesn't have to be removed. I've been searching for about a half-hour now and can find it. I happen to have a used shaft hande thanks to a buddy who did a SAS.
Anyone have a link. Thanks in advance!
thefreqofnature
Re: IFS shaft replacement [Re: thefreqofnature] #772653 12/16/06 08:09 PM
4Crawler Offline
Re: IFS shaft replacement [Re: thefreqofnature] #772654 12/16/06 08:40 PM
I need the write up on replacing the shaft. The FSM is pretty limited on what it shows and discribes. Thanks again.
thefreqofnature
Re: IFS shaft replacement [Re: thefreqofnature] #772655 12/16/06 09:47 PM
A
allochris Offline
it's pretty simple really. Only unbolt what you need, and tighten everything in opposite order. 10 steps for ya!
1)B4 jacking up, stick a 2" thick wood btwn upper bumpstop & UCA to limited down compression (It's easier for me)
2)Jack up and take wheel off
3)undo the big nut of lower BJ from LCA (bj puller)
4)Unbolt manual/auto/flange hub (Hammer and bottle jack small pipe technique. Search for cone-washer removal for more details)
5)Unbolt 12mm bolt & all the snap-rings from CV axle end (btwn the hub and bearing)
6)Undo all 6 bolts from CV inner axle studs. (Mod: You can replace studs with bolts as suggest in link above)
7)Unbolt the huge bearings nut/washer/nut/outer-race/bearing
8)Pull knuckle out/upward by hand for CV axle to slide out from the hole of the knuckle.
9)Pull the whole CV and replace with a new one
10)You are half way done, now put everything back together in reverse order. (Remember to check bearing nuts adjustment, bearing grease, lock-tight, silicon on hub flange, and torque everything.)
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: IFS shaft replacement [Re: allochris] #772656 12/16/06 09:58 PM
A
allochris Offline
oh, this will help. It's not for your year but it's the same thing...
http://www.4x4wire.com/toyota/maintenance/cv_axle/
Re: IFS shaft replacement [Re: allochris] #772657 12/16/06 10:33 PM
Do I need to remove the hub cover in order to remove the hub body?
The heads on the allen bolts are stripped. I've gotten 3 of them off but the others are stripped. So I cant get the cover off. Can I just take the entire hub off with the 6 nuts?
thefreqofnature
Re: IFS shaft replacement [Re: thefreqofnature] #772658 12/16/06 10:56 PM
4Crawler Offline
With manual hub, you'll have either a c-clip or bolt holding the end of the axle shaft inside the locking hub. Cover needs to come off to remove that fastener.
Re: IFS shaft replacement [Re: thefreqofnature] #772659 12/16/06 10:56 PM
Woops the answer is yes...isn't it? Any Ideas?
This is an '88 with Automatic locking hubs. Not sure if that makes a difference.
Thanks again!
Re: IFS shaft replacement [Re: thefreqofnature] #772660 12/16/06 11:45 PM
Shazzzbut...I've got to drill them out don't I. Shazzzbut!
Any Ideas? Who's got the magic?
thefreqofnature
Re: IFS shaft replacement [Re: thefreqofnature] #772661 12/16/06 11:46 PM
Jake97T Offline
are you in yellowstone??? im not far if you need some help
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6402 MB (Peak: 0.7647 MB) Data Comp: Off Server Time: 2026-06-07 04:57:20 UTC
