Misfire on idle. #773266 12/18/06 05:17 PM
Mikeweb Offline OP
I have a problem with my truck running rough at idle. It will occasionally misfire at random intervals.
I've replaced the plugs, cap, and rotor. The plug wires seem good. I think that the timing and idle speeds are where they should be at. I just got done doing the timing chain and everything else that goes with it, but this problem started before I tore all that apart.
Any ideas?
Re: Misfire on idle. [Re: Mikeweb] #773267 12/18/06 05:22 PM
4Crawler Offline
Make sure the Throttle Position Sensor IDLe setting is correct. That can lead to a rough/erratic idle if that is off.
Re: Misfire on idle. [Re: Mikeweb] #773268 12/18/06 07:59 PM
stock87 Offline
Adjust the valves. They can be just slightly too tight so that it wont fire at idle.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Misfire on idle. [Re: Mikeweb] #773269 12/19/06 06:27 AM
Mikeweb Offline OP
Well, I got home tonight and fired it up before I even got online to view replies, and the idle problem has magically disappeared. So I took it out for its first test drive with the new head and cam.
Now it is really hesitating. I think it must be the TPS as you had mentioned. I will take it off sometime tomorrow, because it must have gotten gunked up when I cleaned the throttle body. I was being dumb when I didn't even think to take the TPS off before cleaning it.
Thanks again for all of the help. You guys are great.
Re: Misfire on idle. [Re: Mikeweb] #773270 12/19/06 07:09 AM
toyrunner Offline
Check the timing, you said you think the timing is right.
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6052 MB (Peak: 0.6699 MB) Data Comp: Off Server Time: 2026-05-30 20:32:54 UTC
