04 Tacoma Warn Conversion Kit #773346 12/18/06 09:05 PM
Can anyone suggest, or tell me if there is a manual hub conversion kit available for my 2.7 Tacoma?
Thanks!!
Re: 04 Tacoma Warn Conversion Kit #773347 12/19/06 12:56 AM
My 04 Tacoma has the ADD setup, and according to a few artices, the manual hub bolt on is pretty simple. However, Im unable to find a set that matches the 04 year. I know if you want to lift the truck, a the outer portion of the shaft needs to be replaced with an expensive kit from Offroad Solutions, but all I'd like to do is free up the hubs for improved gas milage and less wear on the front drive. Does anyone have any suggestions?
Thanks!!
Re: 04 Tacoma Warn Conversion Kit #773348 12/19/06 01:26 AM
P
pburruel Offline
Downey Off Road has a kit.
Re: 04 Tacoma Warn Conversion Kit #773349 12/19/06 06:58 AM
Mark in AZ Offline
Toyota Moderator
....all I'd like to do is free up the hubs for improved gas milage and less wear on the front drive.
It is a Toyota and will last a good long time without this conversion....unless you have a 3" lift, that may cause some problems with the front axle boots. Mileage savings...not too likely, or not worth the price of a conversion.
Exploring in a T4R Ltd V8
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5923 MB (Peak: 0.6494 MB) Data Comp: Off Server Time: 2026-05-29 18:12:40 UTC
