Page 3 of 3 1 2 3
Re: Play In Steering Wheel [Re: mlclark] #773615 01/10/07 06:36 AM
langforg Offline
After staring the teardown on my trooper to replace the centerlink/drag link and the tie-rods, I noticed that the pitman arm and idler arm had to be removed in order to get the centerlink out. How do I keep the pitman arm in the correct orientation with the steering box so that when I reassemble the parts, everything is straight. Is there a notch or something that needs to be lined up on the pitman arm? Any info appreciated. I will look at it some more when it gets light outside.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: Play In Steering Wheel [Re: langforg] #773616 01/11/07 04:42 PM
Smiley Offline
IÆm just thinking out loud here, butà
It seems to me that the center link itself would do the job of keeping everything perfectly parallel with the Pitman û once itÆs mounted back on there, the distance between the two arms remains constant; exactly as before --- The concern (as I see it) would be to make sure that the Pitman and Steering Box orientation remained centered, for steering wheel alignment/position purposesà Then any minor discrepancies left-to-right/right-to-left would be adjusted-out via the Tie Rods with an alignment.
That sounds about rightàà right?
(I hope so - I'll be undertaking more-or-less the same project soon)
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Play In Steering Wheel [Re: Smiley] #773617 01/11/07 07:26 PM
langforg Offline
What I ended up doing was marking the pitman arm and the steering box when I removed the arm. Then I just had to line my marks back up. Simple solution really. I don't know why I didn't think of it earlier. Just an FYI for all doing this job in the future.
Brad
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6010 MB (Peak: 0.6713 MB) Data Comp: Off Server Time: 2026-06-11 18:12:42 UTC
