Page 2 of 3 1 2 3
Re: Crankshaft bolt nightmare [Re: bkg] #773969 12/21/06 04:53 PM
Cholltero Offline
turn past TDC, remove #1 spark plug, fill cylinder with nylon rope, remove crank bolt. Easy cheesy.
WINNER ! WINNER!!
85' 4x4 e-cab flatbed 22r carb ((SOLD))
86' 4runner, 22re , "60 buck truck"
95' 4runner, 22re,5sd, last of the good ones
02' Tacoma prerunner, 2.7L, 5spd., 4x4
Re: Crankshaft bolt nightmare #773970 12/21/06 07:02 PM
foxtrapper Offline
Have the starter motor take it off for you.
'97 T-100 SR5
Re: Crankshaft bolt nightmare [Re: subliminaltrips] #773971 12/21/06 07:26 PM
BennyBoy Offline
or pull the coil wire off, slap a breaker bar on it and wedge it up against the frame, bump the starter and violla.... instant bolt loosened... try it, just be careful it only takes a slight bump.
works for me too!
Re: Crankshaft bolt nightmare [Re: Cholltero] #773972 12/21/06 07:28 PM
BennyBoy Offline
WINNER ! WINNER!!
Loser!, as you sqash your rod bearing!
Re: Crankshaft bolt nightmare [Re: BennyBoy] #773973 12/21/06 07:47 PM
bkg Offline
I don't see how this could happen. The nylon rope will give a little, but eventually provide enough stopping power to allow a person to get a stuck crank bolt off.
I've been through these where nothing else has worked... and I mean NOTHING else.
Brian K. Gallus
Re: Crankshaft bolt nightmare [Re: bkg] #773974 12/22/06 12:13 AM
missouriman Offline
I would not do it. bend a rod, break the piston.
you would have to get the rope in pretty even.
side ways pressure and rod will bend or skirt will break.
I would rather try oil on the compression stroke over rope.
Re: Crankshaft bolt nightmare [Re: foxtrapper] #773975 12/22/06 12:58 AM
cktoy Offline
the starter technique works for me.The rope thing sounds like a lot of trouble and it seems like a lot could go wrong
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Crankshaft bolt nightmare [Re: cktoy] #773976 12/22/06 01:07 AM
4WD22R Offline
Starter is the easiest, rope works great, did it on my motor that I just replaced <img src="/forums/images/graemlins/smile.gif" alt="" /> stupid me forgot to take off the bolt before taking the motor out <img src="/forums/images/graemlins/ignore.gif" alt="" /> I've seen a few other people use the rope trick and my neighbor across the street who builds hot rod Chevy's as a hobby swears by it. The oil idea sounds interesting.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Crankshaft bolt nightmare [Re: subliminaltrips] #773977 12/22/06 07:13 PM
W
whitetoy Offline
Another vote for the starter technique, works like a champ.
Be sure to place the breaker bar on top of the driver-side frame, not passenger <img src="/forums/images/graemlins/smile.gif" alt="" />
Rick
1984 4Runner
Re: Crankshaft bolt nightmare [Re: whitetoy] #773978 12/22/06 09:31 PM
Staceman Offline
X2 <img src="/forums/images/graemlins/smile.gif" alt="" />
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6417 MB (Peak: 0.7457 MB) Data Comp: Off Server Time: 2026-05-28 01:05:32 UTC
