Page 1 of 3 1 2 3
Crankshaft bolt nightmare #773959 12/21/06 12:24 AM
OK,
How do you get that stupid bolt off that holds on the timing chain. I have 2 brusied elbows and 3 cut up knuckles. And all the stupid thing does is turn the chain. I am pulling towards the EFI. What is the deal with this stupid stupid bolt.
Re: Nightmare On My Street #773960 12/21/06 01:49 AM
btn Offline
You have to do something to keep the crank from being able to rotate. Put the tranny in 5th and set the parking brake. If you have an auto tranny, maybe stick something through the spokes of the bigger timing gear to keep it from rotating.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Crankshaft bolt nightmare #773961 12/21/06 02:51 AM
ChrisH Offline
'95 Toyota Pickup DX Xtended Cab ~ Daily Driver
Re: Crankshaft bolt nightmare #773962 12/21/06 03:03 AM
cktoy Offline
http://www.4x4wire.com/toyota/maintenance/timingchain/
this should help.Just remember to remove the coil wire. ( from coil to distributor)
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Crankshaft bolt nightmare #773963 12/21/06 03:40 AM
missouriman Offline
get a impact or your best 6 point socket. pull it in the direction of loosen. and smack the end of the handle not your fingers. <img src="/forums/images/graemlins/smile.gif" alt="" /> use a ball peen hammer. I should say hard well placed blows rather then the eyes closed death slam.
remember mr smashy is your friend.
or wait.. edit
are you taking about the bolt infront of the cam shaft or the crank bolt?
my directions are for the cam bolt.
Re: Crankshaft bolt nightmare [Re: missouriman] #773964 12/21/06 03:49 AM
subliminaltrips Offline
or pull the coil wire off, slap a breaker bar on it and wedge it up against the frame, bump the starter and violla.... instant bolt loosened... try it, just be careful it only takes a slight bump.
Re: Crankshaft bolt nightmare #773965 12/21/06 05:03 AM
Snowtoy Offline
IIRC, there is a spot on the camshaft where you can use a wrench to to hold it in place, or let the wrench set against the head.
Re: Crankshaft bolt nightmare [Re: Snowtoy] #773966 12/21/06 03:35 PM
Stevie Offline
Muddy,
If it's the bolt that holds the camshaft gear on, be careful as the gear's somewhat fragile. DO NOT be tempted to jam somethin' thru one of it's holes to keep it from turning while trying to loosen that bolt. Trust dumbass (me) on this one! You'll be either very lucky, or buyin' a new timming set.
'80 4X4 Longbed
Re: Crankshaft bolt nightmare #773967 12/21/06 03:42 PM
Stevie Offline
Muddy..,
And as far as the crankshaft bolt; yeah it's tough. I use a 6 point 19mm and a 24" breakerbar with tranny engaged & brake set. Counterclockwise now <img src="/forums/images/graemlins/shame.gif" alt="" />.
'80 4X4 Longbed
Re: Crankshaft bolt nightmare [Re: Stevie] #773968 12/21/06 04:05 PM
bkg Offline
turn past TDC, remove #1 spark plug, fill cylinder with nylon rope, remove crank bolt. Easy cheesy.
Brian K. Gallus
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6314 MB (Peak: 0.7534 MB) Data Comp: Off Server Time: 2026-05-27 21:08:26 UTC
