Page 3 of 3 1 2 3
Re: Crankshaft bolt nightmare [Re: missouriman] #773979 12/22/06 10:51 PM
bkg Offline
I would not do it. bend a rod, break the piston.
you would have to get the rope in pretty even.
side ways pressure and rod will bend or skirt will break.
I would rather try oil on the compression stroke over rope.
You all are REALLY over thinking the issue here... But, I can't argue with the oil idea assuming the rings can handle it.
If the bolt is on tight enough to bend a rod, it's the least of the issues with that engine...
Brian K. Gallus
Re: Crankshaft bolt nightmare #773980 12/22/06 11:54 PM
MAC Offline
guys in the shop where i work made me up a simple tool out of aluminum. works like a charm for removal and install. bolts thread into pulley bolt holes, lay the bar on the frame on the appropriate side and it holds the crank dead solid, stick the socket on the crank bolt through the center hole. I think the factory SST is this type of tool.
[Linked Image] [Linked Image]
Re: Crankshaft bolt nightmare [Re: MAC] #773981 12/23/06 12:36 AM
willzrunna96 Offline
what ever happend to the good ole' impact gun i do it every time
Re: Crankshaft bolt nightmare [Re: willzrunna96] #773982 12/23/06 01:46 AM
casper3t Offline
but you can't impact if the engine is still in the car unless there a way that i don't know.
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: Crankshaft bolt nightmare [Re: casper3t] #773983 12/23/06 02:57 AM
kewlynx Offline
Air rachet.
Kind of cool to see that tool; I was thinking of something similar for using the threaded holes.
I've also simply dropped the new engine back in and torqued it with the truck in gear before dropping the radiator back in.
**ubi apis- ibi salus**
Re: Crankshaft bolt nightmare [Re: kewlynx] #773984 12/23/06 08:32 AM
4WD22R Offline
+1
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6172 MB (Peak: 0.7034 MB) Data Comp: Off Server Time: 2026-05-26 19:54:27 UTC
