Useful carb info and part number #774105 12/21/06 07:50 AM
stock87 Offline OP
Anyone who has worked on a 22R carburetor knows about the spacer that goes between the carb and the intake manifold.
From the factory the gaskets are attached to this spacer, so you wind up either having to stack the gaskets from the rebuild kit, or trying to file down the spacer and hoping it doesn't leak. Which it usually does.
I sort of automatically assumed the spacer would be about a million dollars from the dealer, but it turns out it's around 20 bucks.
21912-35050
The Napa gaskets don't have the holes for the PCV passages in the spacer anyway; the factory setup works far better.
I'd highly recommend it for anyone pulling their carb off to work on it.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Useful carb info and part number [Re: stock87] #774106 12/21/06 07:56 AM
kewlynx Offline
Thank you; I've got some carb-specific stuff in the p/n thread; will put it there. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
Re: Useful carb info and part number [Re: kewlynx] #774107 12/22/06 01:04 AM
4WD22R Offline
When I rebuilt mine the kit came with new gaskets for the spacer...not a new spacer but I just reused the original. Can't say if it's leaking, I rebuilt the thing about a year ago and it runs fine smile
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Useful carb info and part number [Re: stock87] #774108 12/22/06 02:03 AM
P
poolville02 Offline
thanks! just finished rebuilding my carb and I was trying to figure out why i couldnt scrape the old gasket off the spacer <img src="/forums/images/graemlins/smile.gif" alt="" />
85 Toyota Pickup 4x4 22r 4in lift 32in BFGs
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6020 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-11-14 06:52:46 UTC
