Tightening The Crank Bolt #774240 12/22/06 01:37 AM
casper3t Offline OP
How do you guys tighten the crank bolt on an automatic? i tighten it a little but i don' think its tight enough. its not going to fall off right?
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: Tightening The Crank Bolt [Re: casper3t] #774241 12/22/06 01:55 AM
4WD22R Offline
Make sure you have the correct torque on it should be 116 ft-lbs on a 22R. IDK about about an automatic, maybe put it in park and hope that the park pawl holds everything still? IDK crap about autos so, not sure if this is even possible...IIRC the reason why these bolts are so damn tight when ya take 'em off is because as the crank rotates, it actually tightenes the bolt, again don't quote me on that, and either way definintaly DON'T rely on that to get the proper torque on the bolt. Maybe the torque converter would provide enough resistance to be able to tighten it.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Tightening The Crank Bolt [Re: casper3t] #774242 12/22/06 05:22 AM
cktoy Offline
I have seen pics of someone using a chain whench with a rag to protect the pully.This probably makes it a 2 man job.
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: Tightening The Crank Bolt [Re: casper3t] #774243 12/22/06 09:05 AM
Snowtoy Offline
You need to buy or make a counter holding bar, so you can hold the crankshaft in place while you tighten the bolt.
You can make one like this [Linked Image], cost me less than $3. You could also go to a wrecking yard pull the A/C pulley and weld a bar to it, having a shop weld them together should be rather cheap, less than the $75 the bar costs through a parts store(if you can find them) You then bolt the bar to the crankshaft pulley, set the end of the bar against the frame and tighten the crankshaft bolt.
Yes, the engine vibration could cause it to back out and fall off.
Re: Tightening The Crank Bolt [Re: casper3t] #774244 12/22/06 12:26 PM
foxtrapper Offline
Jam up the serpentine belt with a screwdriver in a pulley. It'll let you get enough torque on the nut.
'97 T-100 SR5
Re: Tightening The Crank Bolt [Re: Snowtoy] #774245 12/22/06 02:12 PM
ACES_HI Offline
Yeah I've seen them come loose too. <img src="/forums/images/graemlins/zombie.gif" alt="" />
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Tightening The Crank Bolt [Re: ACES_HI] #774246 12/22/06 02:32 PM
Stevie Offline
Never had a problem tightening, but when it came to loosening (with the engine removed), used a beveled piece of wood jammed against the belt & pulley. It held enough to loosen: should hold enough to tighten. Good luck.
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6171 MB (Peak: 0.6919 MB) Data Comp: Off Server Time: 2026-06-19 21:33:55 UTC
