A question about pulling my transmission #774889 12/23/06 11:58 PM
mtbikerjohn Offline OP
I'm going to be pulling my tranny soon to replace a broken flexplate,and I was wondering if I can pull the transfer case & tranny separately,or do they have to be pulled together as a unit? It would make things lighter,however,if I'm opening another can of worms by separating the tranny/transfer,then I won't do it..Anybody do it that way? The tranny is a 4L30E,by the way.... TIA...John
Re: A question about pulling my transmission [Re: mtbikerjohn] #774890 12/24/06 06:37 AM
barak Offline
Its not a big deal to seperate the tranny and transfer case.All you do is unbolt the bolts holding the transfer case on , can't remember if its 5 or 6 of them 14MM , and unplug the 2 plugs on the transfer case and undo the speedo cable.Of course this is assuming you allready pulled your drive shafts off too <img src="/forums/images/graemlins/smile.gif" alt="" />I didn't even drain the transfer case , I just plugged the shifter hole(don't forget to take that off too) with a rag and brought it straight down.After that , unbolt your tranny and unhook everything off it and your good to go.You can just slide the tranny back too if you have a jack if your just fixing a flex plate , no point in removing it fully , just enough to get in there and change it.
Re: A question about pulling my transmission [Re: barak] #774891 12/25/06 04:12 AM
Cool! Thanks for the info......John
Re: A question about pulling my transmission [Re: mtbikerjohn] #774892 12/27/06 03:24 AM
90amigo Offline
I used 2 motorcycle straps to help hold the tranny in-place
Hooked them on the Torsion bars and used the jack and straps to walk it into place. <img src="/forums/images/graemlins/smile.gif" alt="" />
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6006 MB (Peak: 0.6569 MB) Data Comp: Off Server Time: 2026-10-24 18:56:14 UTC
