Page 4 of 5 1 2 3 4 5
Re: head gasket time [Re: bassplaya] #774923 01/18/07 08:10 AM
dogtoy Offline
2014 FJ
Re: head gasket time [Re: bassplaya] #774924 01/18/07 08:48 AM
kewlynx Offline
Mine were either a 14 or a 17mm. WHATEVER YOU DO, use a 6 point socket, not a 12, or you'll be sorry...gonna reef on 'em. Alternate your turns on each bolt btw. Follow the book.
**ubi apis- ibi salus**
Re: head gasket time [Re: kewlynx] #774925 01/18/07 07:56 PM
dogtoy Offline
The 3vze has 12 point head bolts, and they are 12mm in diameter. You must use a 12 point, 12mm socket to get them out. Be careful, make sure you do not strip anything, they are tight and tough to get out. Use a little caution and you should be fine.
2014 FJ
Re: head gasket time [Re: dogtoy] #774926 01/18/07 10:59 PM
bassplaya Offline OP
well the only 6 pt socket i have that fits is a 13. a 14 is too big and a 12 is too small. the problem with the 13 is it fits but it just spins on the points.
94 Pickup DLX V6 stock as stock can be, but not for long.
Re: head gasket time [Re: bassplaya] #774927 01/19/07 06:19 PM
dogtoy Offline
12mm 12 point socket! Not a six point socket, a 12 point socket.I repeat, a 12 POINT, 12mm socket. Read what I post you.
2014 FJ
Re: head gasket time [Re: dogtoy] #774928 01/20/07 06:07 PM
dogtoy Offline
How are you doing Bass? Get those bolts off yet?
2014 FJ
Re: head gasket time [Re: dogtoy] #774929 01/29/07 12:27 AM
well its about time for an update. i just pulled the heads off today and am planning on taking them to a shop to get completely reworked.
i did however manage to break a small vacuum hose connector and the small casing on the fuel injector. any idea where i can get one besides a wrecking yard?
Re: head gasket time [Re: bassplaya] #774930 01/29/07 04:29 PM
Stevie Offline
Lots of good Toyota parts wreckers on eBay. Don't know what I'd do without 'em but go broke! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'80 4X4 Longbed
Re: head gasket time [Re: Stevie] #774931 01/29/07 07:11 PM
dogtoy Offline
I broke that same part. I just purchased a new one from the dealer but you could search around the wrecking yards for a used one too. When you buy injector seal kits, that nipple part that is broken comes with it. You need to boil the nipple for a good ten minutes or so to soften it enough to sqeeze on the end. May want to buy a couple extra just incase you break one. Is also a good idea to have your injector professionally cleaned, and balanced, they will replace all the parts for you. Also a good time to take off your starter and replace the brushes and what not, alot easier to get to right now.
Good job! Post a pic of the valve side of the heads if you get a chance. Are 5 & 6 burnt?
2014 FJ
Re: head gasket time [Re: dogtoy] #774932 01/31/07 02:20 AM
well heres the bottom of the heads.
left one
right one
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6382 MB (Peak: 0.7459 MB) Data Comp: Off Server Time: 2026-06-13 10:54:07 UTC
