Page 3 of 5 1 2 3 4 5
Re: head gasket time [Re: dogtoy] #774913 12/31/06 03:18 AM
1
1FastSS Offline
Can you loosen the bolts before the timing belt is removed? Will the belt hold the pully from turning?
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: head gasket time [Re: 1FastSS] #774914 12/31/06 10:52 PM
dogtoy Offline
That could work, sounds like a good way to go. Put the vehecle in gear and set the parking brake and will probably work. That's a good idea, if I am ever in there again, I will try that.
2014 FJ
Re: head gasket time [Re: dogtoy] #774915 01/01/07 09:45 PM
bassplaya Offline OP
well luckily i have a buddy who has the right tool to pull th e cams off but my god what a royal PITA. my next question is one of my fuel injector tips is cracked. is it best to buy an OEM set or is there an aftermarket set that is good? and also i heard that its bad to use the old head bolts. besides the "stealer," where can i pick up a good set?
94 Pickup DLX V6 stock as stock can be, but not for long.
Re: head gasket time [Re: bassplaya] #774916 01/02/07 12:40 AM
dogtoy Offline
There are different injectors available that supply more fuel. I guess it depends on how far you want to go. RAUCH are you reading? This sounds like one for you. Concerning your head bolts...yes, new ones only. If you search around there is a gentleman by name of engnbldr that sells the proper application. After reading all his packed with knowledge posts and genuine human spirit, (that many have commented on), I would not look anywhere else. I would have used his products if the machinist I was working with did not have his own sources that he obviously has established his business with. Give him a call too and tell him what your doing, he is the guru, and has the service to match. Click here~engnbldr.com <img src="/forums/images/graemlins/patriot.gif" alt="" /> Have fun, when this is all over you will be able to rip your motor apart and put it back together within a days time! <img src="/forums/images/graemlins/cheers.gif" alt="" />
2014 FJ
Re: head gasket time [Re: dogtoy] #774917 01/11/07 01:22 AM
quick question and probably a dumb one: is it possible to remove both exhaust manifolds and the crossover as one piece? im having trouble removing the crossover and was wondering if i can go that route.
Re: head gasket time [Re: bassplaya] #774918 01/13/07 10:24 PM
dogtoy Offline
Ya if you can squeeze it through the tight space between the firewall. How is everything going, still peckin away?
2014 FJ
Re: head gasket time [Re: dogtoy] #774919 01/15/07 03:46 AM
im down to the heads now. just working on the bolts. right now im talking to 2 local shops on getting the heads reworked and looking for block damage.
Re: head gasket time [Re: bassplaya] #774920 01/15/07 05:24 AM
dogtoy Offline
Sweet! It's a big job and your half way there. The assembly seems to go much smoother to me. Keep posting, looking forward to your success! <img src="/forums/images/graemlins/kewl.gif" alt="" />
2014 FJ
Re: head gasket time [Re: dogtoy] #774921 01/17/07 07:41 AM
quick question: what size is the head bolts, and do i have to use a 12 pointed socket?
Re: head gasket time [Re: bassplaya] #774922 01/18/07 02:10 AM
i meant to say what size socket. DOH!
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6375 MB (Peak: 0.7455 MB) Data Comp: Off Server Time: 2026-11-14 14:55:34 UTC
