WATER PUMP GASKET #774968 12/24/06 02:15 AM
Thor Offline OP
WHEN installing pump onto block, do you need to put gasket goo on there, or just install it without?
89 Montero, 2.6L 4cylinder. G54B
Re: WATER PUMP GASKET [Re: Thor] #774969 12/24/06 04:23 AM
Jamez Offline
I do beleive you need it. When I replaced my pump I used the gasket with a touch of silicone sealant on both sides and its been leak free since install.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: WATER PUMP GASKET [Re: Jamez] #774970 12/24/06 11:03 AM
Thor Offline OP
okay..hmmm, then i will probably need it for all the other things too...thank you much J.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5912 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-11-05 07:49:16 UTC
