chevy springs? #775298 12/27/06 01:10 AM
U
USMCTRD Offline OP
I already have the hangers and some '06 2500 springs. I got the springs knowing they would be heavy duty, but i figured I could take out a couple leaves. Do ya'll think that would work good or still be too stiff? I want it to be flexy and ride nice, but still lift it a couple inches.
88 V6 4Runner, 2" 4Crawler body lift, 2" suspension, 32x11.50 Pro Comps
Re: chevy springs? [Re: USMCTRD] #775299 12/27/06 01:19 AM
eightyeight Offline
the common chevy swap uses 63" springs from an '88-'98 1500. i think your springs will be shorter, stiffer, and not as flexy.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: chevy springs? [Re: USMCTRD] #775300 12/27/06 01:55 AM
missouriman Offline
how many leaf in each one? are they thick or thin?
many thin ones are better then one thick one.
Re: chevy springs? [Re: missouriman] #775301 12/28/06 04:18 AM
dcg9381 Offline
There are several variants of that particular spring.. I think it's in the pirate faq...
I used a 2wd version, I believe 4 or 5 leafs.
22REturbo.net
1988 4Runner
Re: chevy springs? [Re: dcg9381] #775302 12/28/06 10:04 PM
4x4runner Offline
My springs were off a 2500 GMC truck. Came with 3 springs plus an overload spring which I did not use. The ride is smooth and the flex is great, but no lift. The chevy springs will not lift your truck. I had to use 2" lift blocks so the rear matched the front.
Re: chevy springs? [Re: 4x4runner] #775303 12/29/06 05:19 PM
Rauch_Off_Road Offline
The lift comes when you fab up your hangers etc.
(aka suprathepeg, aka Sean)
Re: chevy springs? [Re: Rauch_Off_Road] #775304 12/29/06 05:25 PM
4x4runner Offline
I do not understand how your hangers will effect your lift unles you add spacers under the hanger welded to the frame and a new hanger?
Re: chevy springs? [Re: 4x4runner] #775305 12/29/06 06:25 PM
Well if you fab up your own hanger then you can dictate the height. Within reason of course. If you pull springs from the pack then you will lose some of the lift too though.
Re: chevy springs? [Re: Rauch_Off_Road] #775306 12/29/06 08:34 PM
4x4runner Offline
I think the discussion here is on the rear springs. I don't think you would want your front hanger sitting low enough to hang up on rocks, just to gain a little lift?
Re: chevy springs? [Re: Rauch_Off_Road] #775307 12/29/06 08:50 PM
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6376 MB (Peak: 0.7561 MB) Data Comp: Off Server Time: 2026-10-31 02:14:09 UTC
