9.5" 14 bolt rearend #775820 12/29/06 02:52 AM
4
4mudder Offline OP
I just got the aforementioned axle from a buddy for a hundred bucks so its going into my 89 k5 and will run 40" tires. my question is will the 9.5" 14 bolt hold up to 40's. Im gettin ready to buy 4.88's and a locker but if its a garbage axle maybe not. thanx in advance.
89 K5 Blazer,TBI 350, 700R4, 6" lift, 40" groundhawgs,3/4 ton 14 bolt rear, 3/4 ton 10 bolt front, 4.88:1 Gears
Re: 9.5" 14 bolt rearend [Re: 4mudder] #775821 12/30/06 04:34 AM
52degrees Offline
14 bolt should be fine for 40" tires.
I'd try to find some heat treated axles for it and an ARB. If you're going to put a lot of motor in front of it keep an extra R/P set or 2 on hand. <img src="/forums/images/graemlins/shiner.gif" alt="" />
KG6VNX
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5841 MB (Peak: 0.6318 MB) Data Comp: Off Server Time: 2026-10-22 01:12:40 UTC
